Re: Reinstalling 4 speed?? [Re: JohnRR] #976301
05/03/11 11:40 PM
05/03/11 11:40 PM
pa
Grant Offline
Grant  Offline
pa
also i'm not familiar with the converter register pilot bearing?? could you let me in on what that is??
Re: Reinstalling 4 speed?? [Re: Grant] #976302
05/04/11 03:58 AM
05/04/11 03:58 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Look at the transmission side of the crankshaft. The large but shallow hole in the center that "centers" the torque converter is where this roller bearing fits. The trans input shaft will extend PAST it into the smaller hole in the crank, but its not a problem. The roller bearing needs to be pressed in full depth.
Re: Reinstalling 4 speed?? [Re: Grant] #976303
05/04/11 10:50 AM
05/04/11 10:50 AM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
I got it machined to fit in the crank fits snug now
There is your problem , the crank is not machined correctly for the 4 speed application, you have to trim the end of the input shaft because the input shaft is bottoming out in the end of the crank , cut 1/4" off and you should be fine .
Re: Reinstalling 4 speed?? [Re: JohnRR] #976304
05/05/11 01:39 PM
05/05/11 01:39 PM
pa
Grant Offline
Grant  Offline
pa
okay, so i got it in. i don't know what the problem was but i took it down one more time and went to put it up and it still came to that little gap and i just kept wiggeling it and it finally went in. But now i have another question. I'm 19 and not all sure about welding but know people that know how to. If i were to just silicone and pop rivot the 4 speed hump in would this work?? or do I HAVE to weld it??
Re: Reinstalling 4 speed?? [Re: Grant] #976305
05/05/11 02:35 PM
05/05/11 02:35 PM
That would be ok , I drove a duster around for years with it just loose on the floor, came in handy when the shifter would jam
Re: Reinstalling 4 speed?? [Re: Grant] #976306
05/05/11 02:58 PM
05/05/11 02:58 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Rivets will work, but be sure to use some sort of sealant to keep water from coming up and soaking the carpet. Automotive seam sealer is the best choice. You can get it in a caulking tube from an auto paint supply store.
Re: Reinstalling 4 speed?? [Re: Kern Dog] #976307
05/05/11 09:32 PM
05/05/11 09:32 PM
pa
Grant Offline
Grant  Offline
pa
awesome, thank you.
now i ran into another delima, i tested out the new steering column to see if all of the lights work and i went to check reverse lights but nothing works on reverse any ideas??? i got a new reverse harness from year one and i used a dmm and i'm not getting any voltage at all from the harness. also the turn signals work but when i turn on the headlights they shut off. any idea why???
Re: Reinstalling 4 speed?? [Re: Grant] #976308
05/06/11 09:19 AM
05/06/11 09:19 AM
awesome, thank you.
Maybe you should start a thread about that and state what year and model car you are working on ?
