Re: rear main seal install ? 340/416
[Re: krw71ragtop]
#975211
04/18/11 12:53 PM
04/18/11 12:53 PM
Posts: 12,016 Finally a HUSKER again
Moparnut426
I think this was my problem. The last kit I pirchased had the tabs seperate from the main seal. Can't remember what company. I didn't cut them off though. I have the new main seal which are the brown seals in this pic. They are Fel-pro #40181. They came with no tabs on them and no tabs in the box.
I have had great luck using the 318 magnum 1 piece gasket. In all cases you have to modify the oil pan to take the tab bump out of the pan rails so the gasket matches the pan. Easy to do with any hammer and dolly, and a welder. None of the 340s or 318s I built have leaked. I with MrP and never stagger the seal. Just made a headache for me in the past.
I also have a high oil psi engine, but no leaks at all. SOMEDAY ill shimm the pump, but for now Im gonna just run 10w40 oil.
Kasey
[Re: MR_P_BODY]
#975212
04/18/11 12:54 PM
04/18/11 12:54 PM
Posts: 892 USA
krw71ragtop
USA
Will the fel-pro black silicone that's in the pic work ok to seal it ?
It should but make sure the surfaces are DRY from any oil(oil the crank so it doesnt stick to it and tear up the joints)
Thanks. I have to go to town so I will look for "The Right Stuff" while I'm there. Now I will clean parts and oil the crank. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: krw71ragtop]
#975213
04/18/11 01:47 PM
04/18/11 01:47 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
For all you guys using Sillycone on your rear main seals ![](/ubbthreads/images/graemlins/tsk.gif) what do you think that will actually accomplish ![](/ubbthreads/images/graemlins/shruggy.gif) Do Not use any sealers on the rear seal itself unless you want to create potential issues ![](/ubbthreads/images/graemlins/Twocents.gif) You have the rear main seal offset in the cap WAY TOO MUCH ![](/ubbthreads/images/graemlins/eeek.gif) another potential issue. For the situation at hand with the motor in the car I recommend offsetting the seal 1/8" (.125") with assembly lube on the back side so it will rotate into position with the other half when the main cap is torqued. Use plenty of assembly lube on the seal lip AND crankshaft as it actually takes a long time for oil to reach that area upon initial start up. The only reason for offsetting a seal is to align the main cap groove with the groove in the block. The seals must mate perfectly square to each other or there WILL be a leak. Main cap to block alignment should always be checked and corrected before any block work is done to the mains, then a referance mark should be placed on the block and cap for proper alingment for assembly. This will eliminate the need to offset the seal. Just speaking from over 20 years of specializing in automotive oil seals so take it FWIW ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Moparnut426]
#975214
04/18/11 05:21 PM
04/18/11 05:21 PM
Posts: 892 USA
krw71ragtop
USA
Kasey
Do you have a part # on that one piece pan gasket ? The parts store I went had one but it said it is used on the 318/360 motor. I asked for a 94 dodge ram application. The one piece I have fits the 360 (1975 LA) I'm building right now. No luck with the 340/318 1 piece.
[Re: roadhazard]
#975217
04/18/11 05:47 PM
04/18/11 05:47 PM
Posts: 892 USA
krw71ragtop
USA
For all you guys using Sillycone on your rear main seals what do you think that will actually accomplish ![](/ubbthreads/images/graemlins/shruggy.gif) Do Not use any sealers on the rear seal itself unless you want to create potential issues ![](/ubbthreads/images/graemlins/Twocents.gif)
You have the rear main seal offset in the cap WAY TOO MUCH another potential issue.
I can only check the seals to see if they mate. That doesn't mean they will mate when they are installed. Main cap to block allignment I did not check. Motor was built 3 years ago. So if both of these issues are off and I do not use sillycone, chances are I will have a leak. But if I use sillycone (silicone) in both thes places, are you saying there is more potential for a leak ? By the way "The Right Stuff" is the wrong price. $20 for a 4 oz tube. ![](/ubbthreads/images/graemlins/eeek.gif)
[Re: krw71ragtop]
#975218
04/18/11 05:55 PM
04/18/11 05:55 PM
Moparnut426
I dont personally use the right stuff, cause its priced like gold. I do however like the stuff from Ford for the 7.3 powerjoke. Its grey and comes in a short caulk tube for 7.80 ish. Dosnt have a very long shelf life if you cut too but a hole in the tip, so I only cut 1/16" hole in the tip. Its kinda thick, but seals like yamabond. VERY good sealant.
Kasey
[Re: krw71ragtop]
#975219
04/18/11 06:16 PM
04/18/11 06:16 PM
roadhazard
Akron, Ohio U.S.A.
They will mate properly if you offset them 1/8" (.125") and NOT the 1/2" or so that appears in your above photo ![](/ubbthreads/images/graemlins/eeek.gif) I only suggest the offset because your motor is together and there is no way to determine the seals will be aligned when the main cap is torqued.
Sillycone Will Not cure the problem of the seal halves not mating properly, trust me. When the main cap is torqued where do you think the sillycone oozes out to?........ Little hint, between the seal and the crankshaft ![](/ubbthreads/images/graemlins/wink.gif)
Only assembly lube should be on the seal (back side and seal lip). Only place for sealer is on the main cap seals if they are of the design that are seperate from the seal itself. (See Photo)
[Re: Moparnut426]
#975220
04/18/11 06:41 PM
04/18/11 06:41 PM
Posts: 892 USA
krw71ragtop
USA
OK,
the 318 fel pro gasket is FPG 0s34408R the 360 fel pro gasket is FPG 0s34409R
Kasey
I checked the local parts store and both gaskets are big in front and small in the rear. Remember, this is a 1970 340 I'm working on. The pan uses the same size seal front and rear.
[Re: Moparnut426]
#975222
04/18/11 07:14 PM
04/18/11 07:14 PM
Posts: 892 USA
krw71ragtop
USA
Dont know then, Ill have to dig through 3 years of notes. May have used a newer front timming cover or something. But I know i built 1 340 2 360s and used 1 piece gaskets.
Ill keep digging..
Kasey
Thanks ![](/ubbthreads/images/graemlins/thumbs.gif)
I think the 1 piece would be less likely to leak compared too the 4 piece. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: krw71ragtop]
#975223
04/18/11 07:17 PM
04/18/11 07:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Ill keep digging..
Kasey
As far as I know they only make the 1 piece for the 360 only ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Moparnut426]
#975225
04/18/11 07:30 PM
04/18/11 07:30 PM
roadhazard
Akron, Ohio U.S.A.
Well I just ran accross my notes on the 2 340s I built, and BOTH engines were dirt late model engines, and BOTH blocks were 360 blocks with callies spacers, so that answers that. That kinda sucks. I knew I had them speced at 340" and they are, just older 360 blocks. Sorry,
Someone needs to do this then. The fella on here who specializes in seals and gaskets should try to get the ball rolling maybee?
Kasey
I'll take donations starting at 10K to do those ![](/ubbthreads/images/graemlins/blush.gif)
[Re: roadhazard]
#975226
04/18/11 07:43 PM
04/18/11 07:43 PM
Posts: 892 USA
krw71ragtop
USA
You make a good point about the silicone oozing out on the crank and the offset. I just want to make sure it won't leak again. That's why I ask so many questions. I appreciate your input along with everyone elses. I've been wrenching on these mopars for over 25 years but not afraid to admit I don't know everything about them and have made my share of mistakes. Thanks again. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: krw71ragtop]
#975227
04/18/11 07:50 PM
04/18/11 07:50 PM
roadhazard
Akron, Ohio U.S.A.
That's what this forum is all about my friend I've had so many people help me out on numerous occasions. Maybe next time you will have one of my seals in there ![](/ubbthreads/images/graemlins/biggrin.gif) Greg ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Moparnut426]
#975228
04/18/11 08:06 PM
04/18/11 08:06 PM
Posts: 892 USA
krw71ragtop
USA
Kasey
Now I can stop looking for something that don't exist Thought the auto parts store guys were smoking to much ![](/ubbthreads/images/graemlins/smoke.gif) My notes must not be as organized as yours. Would have taken me hours to look through mine. Plus this dial-up I have takes forever to respond.
[Re: krw71ragtop]
#975229
04/19/11 11:25 AM
04/19/11 11:25 AM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
You guys are paying way too much for right-stuff ![](/ubbthreads/images/graemlins/Twocents.gif) I buy a big tube for my normal caulk gun and it costs $20 bucks. I have even glued oil pans on with nothing but right stuff and they are some of the driest engines I have seen years later. I don't stagger the seal and I don't put sealant on the seal it self, just the groove.
[Re: krw71ragtop]
#975230
04/19/11 12:54 PM
04/19/11 12:54 PM
Moparnut426
Kasey
I did run accross my notes, and it was easier to call the 2 guys up and just ask them. ![](/ubbthreads/images/graemlins/biggrin.gif)
