Re: Recommendations on Carb Restoration [Re: domingo] #975048
04/18/11 04:21 PM
04/18/11 04:21 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Scott, how long can they sit after the rebuild before they are installed, just trying to know what kind of lead time I need so they dont go bad before installation/use.
They can sit for several years, no problem. I warrant any restoration work I do for as long as you own them, if a problem does occur on startup after storage you can rest assured, I will take car of it. To date I have had zero problems assosiated with customers using them after long term storage.
*Those aren't blasted Domingo, as bad as they appeared "before" they cleaned up rather easily in this case. Blasting is a LAST resort when a really nasty set is being restored, typically it's not required.
Regardless of the level of surface deterioration (or lack of such) the dichromate does leave a somewhat motled surface look, some dull and some reflective areas, photos exagerate the effect depending on the lighting.
As with anything being restored, the better the initial condition, the better the final results will be.
Re: Recommendations on Carb Restoration [Re: not_a_charger] #975049
04/18/11 08:59 PM
04/18/11 08:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Scott, I think he means that the captions for the "before" and "after" pix are reversed.
exactly
Re: Recommendations on Carb Restoration [Re: 68jim] #975050
04/18/11 09:25 PM
04/18/11 09:25 PM
MD, Northern VA
Z
zrwhat Offline OP
zrwhat  Offline OP
Z
MD, Northern VA
WOW! They look fantastic!
Re: Recommendations on Carb Restoration [Re: ScottSmith_Harms] #975051
04/18/11 09:30 PM
04/18/11 09:30 PM
MD, Northern VA
Z
zrwhat Offline OP
zrwhat  Offline OP
Z
MD, Northern VA
Scott,
What is an average turn-around time on a set og Hemi carbs??
Re: Recommendations on Carb Restoration [Re: zrwhat] #975052
04/18/11 09:59 PM
04/18/11 09:59 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
It varies by arriving work load but generally about 4-6 weeks. If you have a specific deadline that needs to be met I can usually work with you to figure something out.
Re: Recommendations on Carb Restoration [Re: ScottSmith_Harms] #975053
04/19/11 04:31 PM
04/19/11 04:31 PM
70RT Offline
70RT  Offline
Used Katter before, next time it'll be Scott! His work is as good as it gets.
Re: Recommendations on Carb Restoration [Re: 70RT] #975054
04/19/11 09:45 PM
04/19/11 09:45 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Ill third or fourth or fifth or what ever number we are up to on Scotts work...did my 4640SA carb last season & its running great. had a few problems with my setup after Scott rebuilt it (not his carb work fault, just some mods previously done to my dist etc) & he helped me get it sorted out
1MYTGTX
Re: Recommendations on Carb Restoration [Re: 1MYTGTX] #975055
04/19/11 09:47 PM
04/19/11 09:47 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Fresh "out of the box"
1MYTGTX
Re: Recommendations on Carb Restoration [Re: 1MYTGTX] #975056
04/19/11 09:49 PM
04/19/11 09:49 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
A before pic...
1MYTGTX
