Re: E Body Blower Motor rubber bushings & sleeves
[Re: ebodyseast]
#97480
07/31/08 07:43 PM
07/31/08 07:43 PM
Posts: 500 NoVa
ebodyseast
NoVa
[Re: moparclown]
#97483
08/02/08 05:23 PM
08/02/08 05:23 PM
Posts: 500 NoVa
ebodyseast
NoVa
I sure do luv sniffin' around the boneyards through the Mopar section, even when most that I know of are picked nearly clean. Great advice!! Time to find a new yard around here anyways. The three small round 2 piece bushings w/ metal sleeves I'd like to replace attach directly to the A/C blower motor & plate assembly, seen in pic below. They seem to function to cushion the blower motor to the a/c box studs just like & identical to how the three wiper motor bushings & sleeves cushion the wiper motor to the firewall studs. The new seal/gasket kit for E body & A/C heater box did include the repro single, large & 'triangular,' a/c box blower motor seal to the firewall - this seals the box to the interior firewall also seen below in pic. Maybe this is the seal you guys are referring? to and I am just misunderstood. Thanks either way guys for taking time to answer and post any pics. So the search is/may still be on for either something generic that is close or used donor pieces from the j-yard. I saw some small round bushings in the Help section and around hanging on hooks for oil drain plugs at Advance Auto that may work out fine for now.
[Re: screamindriver]
#97484
08/02/08 08:19 PM
08/02/08 08:19 PM
Posts: 4,165 Florida
cataclysm80
Those rubber "bushings" were actually part of the whole gasket....And the good news is that the gasket/inserts were'nt E-body specific...Check out some other cars with A/C from the 70s in the boneyard and you'll find what you need...
Been awhile since I looked at one, but I think I agree that the three bushings were part of that triangularish seal. Note that AC boxes and heater boxes are setup differently. By the way, nice AC box. That's one of the early ones held together with screws.
Tav
[Re: ebodyseast]
#97486
08/04/08 11:59 AM
08/04/08 11:59 AM
cataclysm80
As can be seen in the pic below, the triangular 3 pointed seal included in the DMT set does not appear to incorporate the blower motor bushings I've been interested in replacing.
I think that piece seals the box to the firewall, you need the piece that seals the motor to the box. Looks like a great kit, but the seal you're looking for is not reproduced. Most people just find a good used one.
Here's a pic.
Tav
[Re: cataclysm80]
#97487
08/04/08 03:31 PM
08/04/08 03:31 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Tav
Interesting that you refer to that style heater-A/C box as early...My old 70 Challenger R/T S.E. with a SPD of 7/23/70 (very late) had that style box whereas most every other A/C equipt Challenger I've owned including a couple built in 8/69 had the style with the spring clips...
BTW I bought the R/T S.E. off the original 63 year old owner in 1973...
[Re: 1_WILD_RT]
#97488
08/04/08 05:41 PM
08/04/08 05:41 PM
cataclysm80
Tav
I agree that the "early" terminology could be misleading. My 8-26-69 challenger uses the box with screws. I haven't studied it as in depth as I would like, but what I've seen on other cars and heard so far is that the boxes with screws were used on the 70 E bodies and the change to clips took place around early 71 when the B bodies started using the same firewall and AC box. Then the old stock with screws was used up in early 71.
This is the first I've heard of the spring clips being in a 70 car. Are you pretty sure they were original?
Tav
[Re: 1_WILD_RT]
#97490
08/05/08 12:35 PM
08/05/08 12:35 PM
cataclysm80
hmm... I guess this needs to be looked into a little further then.
About 9 months ago I went to a local junkyard searching for half of an AC box because the drains that poke through the firewall had been busted on mine. I managed to round up several of these AC boxes, all out of car, so I couldn't say what make/model each came in originaly. While studying them trying to pick a good one, I found that there were three different types...
One type was held together with screws and J nuts.
A second type was held together with the spring clips. It had notches in the lip for the J nuts, but no holes for the screws.
The third type was also held together with the spring clips, but had No notches for the J nuts nor holes for the screws.
Any of them could be held together with the clips, but to use the screws (like I have) the second type would require drilling where the screws go (not to difficult really), and the third type would require drilling and filing or grinding for the J nuts which is a little more time consuming. Luckily I found a good example for my car that was held with the screws. Inside was a beautiful evaporator. It looked shiny like it was brand new.
So, Do you think the factory used both the screw and clip styles at the same time?
At what point 70-74 was the screw style phased out?
Tav
[Re: ebodyseast]
#97492
08/05/08 07:47 PM
08/05/08 07:47 PM
cataclysm80
Can we get a factory part number in here for anyone else that may have luck scoring an NOS seal? Box above is dated April of '70 for July '70 SPD.
The #s on the one in my picture are... 2936507 53127
Where is the date located on the AC box? That could help me date all the ones in the junkyard next time I'm over that way.
Thanks Tav
[Re: cataclysm80]
#97493
08/05/08 09:12 PM
08/05/08 09:12 PM
Posts: 500 NoVa
ebodyseast
NoVa
Below the part number or casting number, haven't checked to verify which, are 4 digits in this pic...1050, taking a wild guess mind you that this is date code for 105th day of '70. Can I get an amen on this brothers? The part number you give above is a: 24-28-211 blower motor mtg. to unit...well, the rest is up to me now. Wish me luck fellers. Do your little dance for me Benny...
[Re: cataclysm80]
#97496
08/06/08 11:12 PM
08/06/08 11:12 PM
Posts: 500 NoVa
ebodyseast
NoVa
Glad to also finally learn more on this. One vacuum hose and the 2nd hole remains open (not closed with a screw like my part is for now) That extra hole has a story, we just don't what it is yet! Below is the 'vacuum grommet' from a '71 Barracuda I mentioned & as per your request. We may find out that the two port grommet phased out at end of '70 & the single inlet hit the assembley line at some point in the '71 model year, can't offer any specific dates except those already provided. Also seen at the top is an E Body diagram that has a pair of bushings near the blower motor & had me totally off track...
