Re: E Body Blower Motor rubber bushings & sleeves
[Re: ebodyseast]
#97500
09/12/08 11:05 PM
09/12/08 11:05 PM
Posts: 2,592 None
71rm23
None
Tav - while researching this other current topic on '70 E Body relays & delays, etc I came across this a/c vacuumm delay below.
When used, it was probably installed through that second unused hole in the vacuum grommet that we didn't know what it was for. Any opinions? Have any clue what the delay actually does and under what circumstances it was installed?
My heater box for my '71 B-Body has the two holes for the grommet. One goes to the vacuum can and the other to manifold vac? No vacuum delay on my car
