Page 3 of 5 1 2 3 4 5
Re: Pinion Angle - here we go.... [Re: gregsdart] #973505
04/16/11 11:24 AM
04/16/11 11:24 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
(Why did I let myself get drawn into this mess?)
Motor/transmission center line in relation to pinion center line = proper way to measure. Not too difficult, some don't get it. Some will argue till the moon turns to swiss cheese. physics says this is the proper way to cancel change in speed due to an angled joint. Run the joints ninety degrees to each other, all is good if the trans and diff are close to parallel. Some angle is needed to properly keep the joints lubed and keep the needles from flattening due to being at the same spot all the time. If the engine/trans measurement didn't matter, then the diff angle wouldn't either. Run one too far out of alignment, you get broken trans parts. I will try and load a photo.
If the trans is pointing down and the diff is pointing down, add them. If either is going a different direction, subtract the smaller angle from the larger. If both are pointing up, fix em.
thats how i set mine also, i don't use the driveshaft. this is also the way Calvert recommends.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Pinion Angle - here we go.... [Re: 68 HEMI GTS] #973506
04/16/11 01:13 PM
04/16/11 01:13 PM
tboomer Offline
tboomer  Offline
Kevin....Talked to Steve this morning...Just haul it up to Ames and put it on the rack..You guys will be done in no time!! PS...Enjoy this beautiful day we are having!
Re: Pinion Angle - here we go.... [Re: MR_P_BODY] #973507
04/16/11 05:35 PM
04/16/11 05:35 PM
USA
540DUSTER Offline
540DUSTER  Offline
USA
Listen to MR P BODY,the best pinion angle for a four wheel drive truck that is lifted four feet off the ground is not going to be the best for a race car.
Re: Pinion Angle - here we go.... [Re: deaks] #973508
04/16/11 06:02 PM
04/16/11 06:02 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
I went off the rossler chart and mine is 6 degrees down on SS springs but i think you might need a little less with caltracs.
Mick
using my numbers and the Rossler chart -- what do you come up with ?
Re: Pinion Angle - here we go.... [Re: 493_DART] #973509
04/16/11 08:18 PM
04/16/11 08:18 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
.... I thought it was the front axle pinion angle that was hard to do
Re: Pinion Angle - here we go.... [Re: 493_DART] #973510
04/16/11 09:39 PM
04/16/11 09:39 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
thanks Sport ---
Now , we also have the crowd that uses the pinion measurement and the D shaft measurement....will their results be the same numbers ?
No, You only gave One set of numbers between the pinion and the driveshaft.
Those were 4* down Shaft and 10* Down Pinion, witch would give you a "Driveshaft /Pinion angle of 14*
I will Edit my post to include that for a perspective.
OK, here is what i meant ---
there are people who measure the shaft and the pinion.
your method is the Trans and the pinion. correct?
here is what i mean :
skip to about 2:00
http://www.youtube.com/watch?v=i8FNgaNqS8s
notice this guy doesnt include any trans angle
And Did You notice, he's working with a 2 piece driveshaft. He states this works on Mustangs with a 2 piece shaft from 2005 on up.
Dont get me wrong You can get by with using the driveshaft. Its just not as accurate.
In MR.Pbodies car, he built his engine/tranny driveline paralell to the pinion. He and anyone else who does the same can accurately set the pinion angle off the Shaft.
People with Unmolested drivetrains can set the pinion angle off the shaft and still not have problems. Though the accuracy of the true pinion angle wont be known. As long as your getting a negative angle reading between the two of 3* to 5* or so. The U joints will do thier job and you wont notice anything most likely.
With a modified car such as yours, I think one can see you wouldnt want to measure it off the Shaft.
Your current measurements between the shaft and pinion give you a neg/-14*
Your current measurements between the tranny centerline and pinion give you a neg/-9*
Both sets of numbers are telling you, that your pinion angle is to far negative. If your measurments are "correct"
With your combo you dont want your pinion angle set to a positive angle. On Your ride, I wouldnt use the Shaft.
If you do, You may get a Shaft Attack.
Re: Pinion Angle - here we go.... [Re: 493_DART] #973511
04/17/11 03:13 AM
04/17/11 03:13 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mick
-3
Mopar Performance
Re: Pinion Angle - here we go.... [Re: moparniac] #973512
04/17/11 03:58 AM
04/17/11 03:58 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Sport --- i didnt know about the 2 piece shaft. thank you sir. I agree about the accuracy of my measurements...some are hard to see / laying on the floor/ angle finder has magnet on only on side--you have to hold it in place / ETC>>>> So, im going to spend some time and re-measure everything to be sure.
wedgie --- thanks , where do you see those numbers--im looking at the chart now....... have you been photo-shopping again ...?
Re: Pinion Angle - here we go.... [Re: 493_DART] #973513
04/17/11 04:03 AM
04/17/11 04:03 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
yes! I put your numbers in you listed from those measurements places! figured id help you out with a visual
Mopar Performance
Re: Pinion Angle - here we go.... [Re: tboomer] #973514
04/18/11 02:57 AM
04/18/11 02:57 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
haha ...... i was trying to get all the opinions and methods covered here so i could "pick a number "
i dont like to bother steve and jim too much - i know they are busy --they dont even have time to work on THEIR cars right now.
however.....ive never aligned this car yet..
Re: Pinion Angle - here we go.... [Re: 493_DART] #973515
04/18/11 08:36 AM
04/18/11 08:36 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
When building a race car chassis point the pinion directly at the trans output shaft then make the final adjustment(pinion angle) off the pinion and shaft.On a car already built,just adjust the pinion to the shaft.
Re: Pinion Angle - here we go.... [Re: B G Racing] #973516
05/09/11 05:51 AM
05/09/11 05:51 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
this thread went like i thought....
tried this tonight :
http://www.wolferacecraft.com/pinionangle.aspx
i got 5 degrees down
Re: Pinion Angle - here we go.... [Re: 493_DART] #973517
05/09/11 10:08 AM
05/09/11 10:08 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Wolf only builds the fastest stock suspension cars in the country and your going to listen to them
Re: Pinion Angle - here we go.... [Re: sixpackgut] #973518
05/09/11 03:49 PM
05/09/11 03:49 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
What happens when you use that method to set the pinion angle in a car with the rearend higher than the transmission?
Re: Pinion Angle - here we go.... [Re: 68 HEMI GTS] #973519
05/09/11 04:07 PM
05/09/11 04:07 PM
canada,NB
jb15 Offline
jb15  Offline
canada,NB
Same here aswell
Re: Pinion Angle - here we go.... [Re: DoctorDiff] #973520
05/09/11 05:05 PM
05/09/11 05:05 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
With the pinion rotating upward from a DS thats going in a downward direction too the trans tailshaft i would say you'd be screwed, to me thats a + angle, unless the trans tailshaft rotated up & the rearend stayed stationary . The way i set mine, I put my trans tailshaft at 0, then i ajust the rearend nose down to where i want it, Now if i measure the -3 on the nose, & measure the downward angle on the driveshft (which still is a - angle, It could add up to -6-7, so i just ignore the driveshaft angle.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Pinion Angle - here we go.... [Re: DoctorDiff] #973521
05/09/11 05:17 PM
05/09/11 05:17 PM
USA
540DUSTER Offline
540DUSTER  Offline
USA
Why not shim the trans up until it was pointing at the rear?
Re: Pinion Angle - here we go.... [Re: joedust451] #973522
05/09/11 05:30 PM
05/09/11 05:30 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The answer is simple.
Make the pinion parallel to the transmission as a baseline, then rotate the pinion downward 2-4 degrees and weld the perches/brackets.
Unless the vehicle is severely raised, this method works every time for applications with 2-joint driveshafts.
Re: Pinion Angle - here we go.... [Re: DoctorDiff] #973523
05/09/11 06:10 PM
05/09/11 06:10 PM
organ
maximum entropy Offline
organ
please, everyone, FOR THE LOVE OF GOD, this is the way. just do it this way. please.
Re: Pinion Angle - here we go.... [Re: maximum entropy] #973524
05/09/11 06:25 PM
05/09/11 06:25 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
