Re: cant figure this out_440 pops and lacks power ...
[Re: AK_JH27]
#972716
04/14/11 12:08 PM
04/14/11 12:08 PM
Posts: 134 Anchorage,AK
AK_JH27
Anchorage,AK
thanks for all the replys this weekend is "work on the charger w/e" some facts, the carb is the edelbrock 1401 or 14xx cant remember, its the same on my challenger and it works great, i dont think its the carb. vacum advance is hooked up, wires are on corrrectly, fuel doesnt seem to be an issue,i have a electric pump, it does pop thru the exhaust though, maybe bad exhaust vavles? i'm leaning towards a bad cam. i'll report my findings this week.
[Re: dOc …]
#972718
04/14/11 12:47 PM
04/14/11 12:47 PM
Posts: 843 Suffolk,VA
ireland383
Suffolk,VA
TIME to find-out what your fuel pressure is.
I agree, you need to find out your fuel pressure.
[Re: ireland383]
#972723
04/14/11 01:29 PM
04/14/11 01:29 PM
Posts: 30,491 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
![](/ubbthreads/images/graemlins/laugh2.gif) You know the word CRAB was an error in spelling THEN it stuck ... 'specially ferr 'da Bumz ![](/ubbthreads/images/graemlins/thumbs.gif) MY experience with this situation .. I have had a combo go lean and fat. Lean was when I was doing some major tweaking on a TQ ... I changed the secondary jets and FORGOT to tighten one down. It fell off(and that cut-off 50% of the fuel in the secondaries) ... then the car was popping and banging SURGING big-time. Later that month I took it to the track..... muffs, OEM dual-snorkel air-cleaner and all..... it would lazy nose-over when you got into the higher revs .... MPH was not what it should be. I double-stacked the AC element ... problem solved ![](/ubbthreads/images/graemlins/thumbs.gif) THAT situation was going way FAT.
[Re: AK_JH27]
#972725
04/14/11 05:07 PM
04/14/11 05:07 PM
Posts: 5,908 Athens, Greece
Pyper70
Athens, Greece
I have the Eddy 500cfm and the eddy 750. If you put your foot down, maybe you need some more fuel. Is your accelerator pump linkage on the middle hole? Try readjusting it to the bottom hole, it will allow more fuel to come in. Your jets/rods would be another question. They are usually pretty good from the factory but you have some fine tuning in your future to perform. Are there any vacuum leaks? Is the back port on the carb sealed? I have vacuum lines coming off mine and maybe you have a fray or crack in yours. I have but one car and I saved up some cashola to buy an Air/Fuel readout so I can fine tune the carbs. If you have another carb as you say...doesn't hurt to spend 15 minutes and take it off the other car, all the fuel lines will hook up the same way too. How many miles you have on that cam? Hydraulic? Solid? If you think its the cam I dunno how to go about checking it. It'd be the blind leading the blind...maybe pull a lifter and check the bottom for damage ![](/ubbthreads/images/graemlins/shruggy.gif)
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#972726
04/14/11 05:24 PM
04/14/11 05:24 PM
Posts: 277 Cincinnati, Ohio
chargincharles
Cincinnati, Ohio
Hate to add fuel to THIS fire.. but if the engine IS NOT rebuilt- He may have excessive slack in the timing chain, or he may have slipped a tooth. Wouldn't show up at light throttle, but would alter the timing enough to cause an issue under load. Stupid Plastic-toothed 'Silent' drives were known for this kind of issue. Just my ![](/ubbthreads/images/graemlins/Twocents.gif) CC
[Re: chargincharles]
#972730
04/15/11 12:46 AM
04/15/11 12:46 AM
Posts: 576 Hr up from KCK
451 D*O*D*G*E
Hr up from KCK
Knew a car that did this..was a pin hole in the fuel line where it ran through the crossmember. ![](/ubbthreads/images/graemlins/musik010.gif) Also second poster beat me to it...the bad coil.You try another?I hada Duster that went to acting like that and finly got a real mopar ol timer to come over..he listed looked around and said..you got another coil?I said yes and slapped it on and away we went!
1970 Challenger R/T clone
2010 Dodge Journey R/T black,awd,
[Re: AK_JH27]
#972733
04/15/11 04:12 PM
04/15/11 04:12 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
is the vacuum advance on ported vacuum? ![](/ubbthreads/images/graemlins/shruggy.gif)
