Re: Indy 470 stroker kit.???????? [Re: viperblue72] #972399
04/15/11 08:04 PM
04/15/11 08:04 PM
Manitoba, Canada
O
Overdrive440 Offline
O
Manitoba, Canada
I'm looking for info for building a 470 as well. If you do go with machining a used 440 crank, what would you use for rods? Are there Chevy length rods with Chevy journals and pins that have Chrysler journal widths?
Re: Indy 470 stroker kit.???????? [Re: Overdrive440] #972400
04/15/11 08:26 PM
04/15/11 08:26 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
I am running a stock crank offset ground and mains turned down. I would not do it that way again. I would buy a new crank. I ended up with as much money in the stock crank. My last 2 cranks have used chev rod on mopar width rod journal.
