Where to get fuel rails for Indy small block manifold?
#970902
04/10/11 10:40 PM
04/10/11 10:40 PM
Posts: 13 Oxford, OH
Blue93Dakota
Oxford, OH
Anyone know where I can get fuel rails for my Indy headed R3 small block? Can I buy them ready to bolt on or do I have to buy extruded rails and machine them to fit?
93 Dakota Club Cab
R3 Turbo Build in progress
Re: Where to get fuel rails for Indy small block manifold?
[Re: TheOtherDodge]
#970904
04/10/11 11:48 PM
04/10/11 11:48 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
Standard smallblock edelbrock rails here....I just had to drill the intake to match the hole pattern, and also had enough meat left to drill the intake for the edelbrock holddowns..... The rails are dirt cheap, and all you need is a bit for drilling the intake....if I get a chance tomorrow, I'll look around for the right bit.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: instigator]
#970905
04/10/11 11:58 PM
04/10/11 11:58 PM
instigator
north cakalaky
http://www.summitracing.com/parts/EDL-3641/?rtype=10The rails from summit... I may have had to mill down the pads on the intake some to get the proper height....can't remember....though something most any machine shop with a mill should be able to do. I beleive indy has a kit, but I imagine it would be an arm and a leg.... was enough to flow enough fuel for 980whp on a mustang dyno this past week....
[Re: joshking440]
#970907
04/11/11 02:29 AM
04/11/11 02:29 AM
Posts: 2,091 Delray beach, Florida
Performance Only
i have a complete setup on the shelf. has wilson fuel rails, injectors, throttle body and 90 degree wilson adapter. manifold is for 360-1 heads. everything is brand new.
machine shop owner and engine builder
[Re: RyanJ]
#970909
04/12/11 10:18 PM
04/12/11 10:18 PM
Blue93Dakota
Oxford, OH
Thanks for all the replies. Don't want to sound stupid, but I lost track of this thread. Not familiar with this site yet. Got a PM from one of the members on here. Going to go with his as long as the measurements match up. He's got lines, fittings, rails, Y-block, and regulator all included.
Ryan, I should be able to just measure my stockers and make sure his measure the same then correct?
93 Dakota Club Cab
