ANYONE USE A TURBO WING ON THEIR PICK UP ROOF
#970736
04/10/11 07:12 PM
04/10/11 07:12 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
is it worth using one when towing ? any better on fuel or better handling ? oh no that's what you think
home of the Sox and Martin Hemi Duster
Re: ANYONE USE A TURBO WING ON THEIR PICK UP ROOF
[Re: rickstershemi]
#970742
04/10/11 08:45 PM
04/10/11 08:45 PM
Posts: 52,972 Romeo MI
MR_P_BODY
They do work if they are adjusted correctly....the trailing edge needs to hit an intersecting line drawn from the forward tip of your hood to the tip of the front of the trailer at it's highest point
Rickster
Yep
[Re: HEMIFRED]
#970744
04/11/11 02:23 AM
04/11/11 02:23 AM
Posts: 730 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
I use to tow a 28ft trailer with a gutless 302 ford f250. going down the hiway, flat out with no wind, I could go about 62 MPH. added the wing, and besides keeping the bugs off the trailer, top speed went up to 70!!!
It was still a pig, but i could almost keep up with traffic.
so they do work.
Joe
Without Data, you’re just another guy with an opinion.
[Re: MR_P_BODY]
#970747
04/11/11 01:22 PM
04/11/11 01:22 PM
HEMIFRED
SOUTH JERSEY
I just called the wing's manufacture for info on mounting brackets. No wing will do any improvents to my truck. Their tech guy told me the wing needs to be no more than 6' from the trailer an open pick up pulling a tag gets nothing It will work in a pick up with a goose
[Re: dusturbd340W5]
#970749
04/11/11 04:26 PM
04/11/11 04:26 PM
MR_P_BODY
I had the same problem had 1 for a while it worked with the 5th wheel did nothing with my 32' tag.
To great a distance to the trailer, the air has a larger area to fall back in... I was in a design stage of a rubber cover that would mount to the cap of the truck and snap to the trailer(both the top and sides)
[Re: MR_P_BODY]
#970750
04/11/11 05:29 PM
04/11/11 05:29 PM
HEMIFRED
SOUTH JERSEY
BECAUSE I DON'T HAVE ONE I NEGLECTED TO MENTION HE DID SAY A CAP WOULD MAKE IT WORK
