Re: 1965 / 1966 Fury's ..what tire size have you used
[Re: SPWC]
#96967
07/31/08 08:09 AM
07/31/08 08:09 AM
Posts: 35,155 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
do you have a side view of it ?
I'm not worried about rubbing, worried about getting them on
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: SPWC]
#96969
07/31/08 10:51 AM
07/31/08 10:51 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
big improvement
Don't suppose you have a closer view even if it was just the tire(s) and wheel(s)
[Re: SPWC]
#96973
07/31/08 11:04 AM
07/31/08 11:04 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Also, there is two 65 wagons laying in the weeds by here that if needed can get parts off of
The one, I prefer to wait till cooler weather would show up cause , I think its most likely a snake house
[Re: SPWC]
#96975
07/31/08 11:06 AM
07/31/08 11:06 AM
Posts: 4,102 Cochise County Arizona
SPWC
Forget the steelies...you know you want to (these 17" TTO copies are not a bad price..)
Ya know those are nice but EVERYONE has those,my only issue with those wheels
[Re: SPWC]
#96979
07/31/08 11:19 AM
07/31/08 11:19 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
This thing is a MAJOR job to put rears on We have to put it on a 4 post lift and use the jack to lift it way in the air , drop shock bolts
Unhook brake line brackets ..
But, the wagon is different, if you ae driving and have a flat, well . then what ?
[Re: bigdad]
#96981
07/31/08 01:46 PM
07/31/08 01:46 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Around $800 a set for 17's
'in guy like you would be able to swing a few sets I'm sure..
200 a piece for knock offs ?
These are USA made (local) and believe real TT's are up there abit too (and think these are like $195 per?)
The American Eagle versions where right around the same price, but they are not going to be around for long..(and hard to get now with production way down on them)
[Re: bigdad]
#96982
07/31/08 01:53 PM
07/31/08 01:53 PM
SPWC
I jack the car up by the front leaf spring mount with a floor jack.
