Page 2 of 3 1 2 3
Re: stuck dampener [Re: 540challenger] #969081
04/08/11 11:26 AM
04/08/11 11:26 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Some of the nicer pullers come with a insert to put into the crank so this doesn't happened.
Yeah mine is a cheap one, but it had a button that goes on the end.
It was lost in the crank cuz I removed the washer, then didn't replace the bolt. Ruined the crank but I still use the puller just need to remember to replace the nut after removing the big washer. We live we learn.
Re: stuck dampener [Re: bboogieart] #969082
04/08/11 11:40 AM
04/08/11 11:40 AM
NY usa
540challenger Offline
NY usa
I got that topped. My friends dad who was a mechanic showed me how to remove a damper with the proper tool. So after using the PRY BAR i learned fast how not to pull a damper
Re: stuck dampener [Re: 70Cuda383] #969083
04/08/11 11:46 AM
04/08/11 11:46 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I just used mine this morning to remove a flywheel from a 12 HP Briggs on a old riding mower. It's one of the first tools I ever bought for working on motors, I'm on my 3rd one.
I ruined one trying to pull a welded on hub off a racing hemi.
Got one at home and at work.
Re: stuck dampener [Re: Challenger 1] #969084
04/08/11 12:00 PM
04/08/11 12:00 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
C.A.T. dampers tell you to heat that bad boy up in a pan of boiling water prior to putting on. Imagine getting that thing off..Oh yeah, I did..with a balancer puller! Maybe a smear of anti-seize next time?
Tell us how that steering wheel puller worked out
Re: stuck dampener [Re: pishta] #969085
04/08/11 12:10 PM
04/08/11 12:10 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
The worst balancers EVER are the late model smallblocks with the one piece cast hub with the integral crank pulley.
You need something that grabs the hub from the inside to pull it.
If you can pull one of those, suddenly every other balancer is gravy.
Re: stuck dampener [Re: 540challenger] #969086
04/08/11 12:29 PM
04/08/11 12:29 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Seen a fluid dampener or two that were a bear to remove. All others come right off with decent puller.
Good point a fair amount of aftermarket dampers can bee too tight or too losse depending on the brand. To tight is not a bad as you cam hone it slighty to get a better fit.
All the aftermarket dampners I have purchased come with a sheet telling the end user that the dampner must be honed to size , this is why they are hard to install.
Re: stuck dampener [Re: JohnRR] #969087
04/08/11 12:55 PM
04/08/11 12:55 PM
Marysville, O-H-I-O
70Cuda383 Offline OP
Marysville, O-H-I-O
All the aftermarket Dampners I have purcahsed come wit ha sheet telling the end user that the dampner must be honed to size , this is why they are hard to install.
right. I don't think this one was honed to fit.
Ive never had one give me this much trouble. I'll have to get a puller and try again later.
**Photobucket sucks**
Re: stuck dampener [Re: JohnRR] #969088
04/08/11 12:56 PM
04/08/11 12:56 PM
Cincinnati, Ohio
Cincinnati, Ohio
I guess because a damper must be firmly installed on the crank to absorb vibration.
Re: stuck dampener [Re: 70Cuda383] #969089
04/08/11 12:58 PM
04/08/11 12:58 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Um... Just buy the tool... The good puller/installer is $100. You're hammering directly on the crank. You might as well be throwing the hammer from the slide hammer at the crank... It's not hard to bend the crank doing that. Especially a cast crank...
Re: stuck dampener [Re: Challenger 1] #969090
04/08/11 01:03 PM
04/08/11 01:03 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
BETTER for the dampner to be a little tight ...than loose for the dampner to be effective.
B U T ... as tight as some of these are(as some are describing it) .....
How the HELL did they get the dampner ON the crank in the first place ? ......
...WITH a BFH ??
Re: stuck dampener [Re: 70Cuda383] #969091
04/08/11 01:29 PM
04/08/11 01:29 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Dont get a 3 finger puller. You want one that will bolt to the dampners base. I made one myself years ago with multiple holes to fit ford/chevy and moper dampners.
Re: stuck dampener [Re: Sport440] #969092
04/08/11 02:43 PM
04/08/11 02:43 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
The 3 fingers or legs are the only ones in-use 99% of the time. I loaned my Old Forged(USA made) one out to someone ... and never got it back and went out to bought a ChinaMart one(cause I was in a bind)....
Worked fine. but as I said above .... it worked better using a 24v 1/2" impact gun.
Re: stuck dampener [Re: dOc !] #969093
04/08/11 03:06 PM
04/08/11 03:06 PM
ILL
Roger 68 Charger Offline
ILL
I just finished putting my dampener on (PRW) Man what a pain--I heated it up in water and used anti seize--but it went on hard all the way. The instructions didnt say anything about honeing and I didnt think of it
Man that thing is going to be a pain in the ass to get off
68 RT charger 70 Cuda 99 Durango
Re: stuck dampener [Re: Roger 68 Charger] #969094
04/08/11 03:07 PM
04/08/11 03:07 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
my TCI Rattler was 2.5 thou pressed fit - I had it honed to 1.5 thou press fit - thats what was recommended by the machine shop.
Re: stuck dampener [Re: 70Cuda383] #969095
04/08/11 04:32 PM
04/08/11 04:32 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
One thing to remember: any impact on the damper is transferred directly to the crank and thrust bearing.
If it's an engine you don't plan on rebuilding, don't hammer on (or off) the balancer.
- Stu Harmon
Re: stuck dampener [Re: feets] #969096
04/08/11 04:36 PM
04/08/11 04:36 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
To the guys that have had to honed-to-fit these things ....what have you used to do-so ?
Re: stuck dampener [Re: dOc !] #969097
04/08/11 04:57 PM
04/08/11 04:57 PM
Cincinnati, Ohio
Cincinnati, Ohio
A small engine hone...
Re: stuck dampener [Re: Challenger 1] #969098
04/08/11 05:09 PM
04/08/11 05:09 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
LIKE a wheel cyl hone ? ... or maybe a smaller dingle-berry ? ....I have TWO of these to "fit" down the road.
Re: stuck dampener [Re: Roger 68 Charger] #969099
04/08/11 05:12 PM
04/08/11 05:12 PM
JohnRR Offline
JohnRR  Offline
Maybe it was written in a language you couldn't read ... like CHINESE ...
If you have an aftermarket crank you can't count on them being in spec eiter definitley should have done some measuring.
I would have stopped and not went all the way on with it if it was fighting all the way on.
Re: stuck dampener [Re: Challenger 1] #969100
04/08/11 05:12 PM
04/08/11 05:12 PM
JohnRR Offline
JohnRR  Offline
I had it done at the machine shop , he measured it and did it in the rod hone .
Page 2 of 3 1 2 3
