Re: What did I do wrong on my ministarter
[Re: JohnRR]
#968601
04/09/11 06:50 PM
04/09/11 06:50 PM
Posts: 30,460 Florida STAYcation
dOOc
The village idiot's idiot
Florida STAYcation
Doc got me cranked up this morning.
Wouldn't it be nice if when you put some d'bag on your ignore list that it wouldn't allow them to open or reply to anything the ignorer posted ?
Hay RoadToad .... d'bag ? ...I know you are .. but what am I ?
And what ever happened to you ignoring what I say? .... or is it that you just can't stay-away from getting your own garbage thrown back in your face? I could go on-and-on about how I have spanked-you and shown others what a true d'bag YOU ARE ... but I will use YOUR exact-words to show all what a "MR Personality"(not!) you are .....
""""" Same here , in general people annoy me just with their breathing """" ...
You did not put in-there a or a . You are a true anti-social malcontent. And many MANY of your posts prove that.
Now as far as C1 and what he said. We have jabbed each other almost done since day one ...and all done in fun(at least I thought it was). THIS time ? ... it is obvious to me that he is not taking it that way. Is he having a bad-day ?
If so ...I am sorry if it is for him. ....
But YOU ? ... I look-FORWARD to a with you. I have previously SPECIFICLY avoided posting on a topic that you are on. NOW I look forward to it.
[Re: 69L78Nova]
#968603
04/09/11 09:03 PM
04/09/11 09:03 PM
Posts: 3,445 N.Wilkesboro,NC
DusterKrazy
N.Wilkesboro,NC
I would have to disagree with you on this one. The stock "Boat Anchors" require more current draw and perform less effectively than the mini-starters. I won't even touch the fact that header interference with the stock starters is a PITA. Come on...step up to the 21st century and start running those mini's....
These cars were built with those "20th century" starters. Sure the OEM units are a little tougher to get in and out, but I have NEVER had a problem with fitment isses with headers out of all the cars I have had. I have a pile of the mini starters laying in my shed. I refuse to use them. I dont want my Charger or my Fury sounding like a Nissan when its turning over
I could care less what it sounds like when it's turning over. The sound after it starts is what matters
[Re: DusterKrazy]
#968604
04/09/11 09:08 PM
04/09/11 09:08 PM
dOOc
Florida STAYcation
With a 'tude like that DK .. you are not a true Mopar guy ...
[Re: dOOc]
#968605
04/09/11 11:11 PM
04/09/11 11:11 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
WHOA! Calm down people. Doc and Ihave been breaking ea. other's stones all in fun. Just 2 guys with spending too much time on the internet. My time on the web just happens to be more fun than his because his library has a porn filter. Now, back to the starter..... S Some more Googling brought up an issue talked about in several forums that hasn't been brought up here. Some people have found the nose cone not machined correctly and causing a misalignment. I'll do a little shaving and I'll report back.
[Re: Commando1]
#968606
04/09/11 11:49 PM
04/09/11 11:49 PM
dOOc
Florida STAYcation
I'll do a little NAPING and I'll report back.
His LAST LINE is "fixed" !
...and I have not been to the 'brary in quite a while ... since the foxy 'brarian is gone ....
[Re: dOOc]
#968607
04/10/11 08:47 AM
04/10/11 08:47 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Hey Doc, we all know you and Commando1 just joke with each other, so, any chance you PMed a Moparts member and convinced him to post this?
[Re: B5 Bee]
#968608
04/10/11 09:16 AM
04/10/11 09:16 AM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
YIKES, i've been busted!!!
[Re: B5 Bee]
#968609
04/10/11 10:37 AM
04/10/11 10:37 AM
dOOc
Florida STAYcation
What ME ? ... .... seriously NO ... but I beez liken' that guy !
[Re: ToddP]
#968611
04/10/11 11:02 AM
04/10/11 11:02 AM
dOOc
Florida STAYcation
I have seen starters spin on the bench, but not turn over the engine.
GOOD POINT TP .... but anything that C1 has .... is so weak you could spin-it-over with a speed-bar
...and YES .... I am just gettin' WARMED UP ...on a rainy Sunday morn' ..
[Re: dOOc]
#968612
04/10/11 11:27 AM
04/10/11 11:27 AM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
*** You are ignoring this user ***
[Re: JohnRR]
#968614
04/10/11 02:51 PM
04/10/11 02:51 PM
dOOc
Florida STAYcation
You remove what you say ? ...Ahhh RoadToad .... so does this mean you wanna' be Buds ?
[Re: Kern Dog]
#968616
04/10/11 03:41 PM
04/10/11 03:41 PM
Commando1
JOHN: Got To your room! DOC: GO STAND IN THE CORNER! Sheesh. Time out for both of you. Problem solved!!!!!!!!!!!!!!!!!!!!!!!! As I mentioned above, I found several hitswhile Googling the problem that said that sometimes the nose cone wasn't machined properly causing the Bendix to hang up. HELLO! I shaved a little off the nose cone and it works perfectly. Now you all know a little bit more about mini starters than you did yesterday. 62 and still learning.
[Re: Commando1]
#968618
04/10/11 04:46 PM
04/10/11 04:46 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
Yep, I see mine doesnt seat all the way either. I am waiting till I have the inspection shield to see if it sits flat then. If it dosnt I'll have to do the same thing.
[Re: POS Dakota]
#968619
04/10/11 05:00 PM
04/10/11 05:00 PM
Posts: 3,344 Central TX
roe
Central TX
Maybe it was necessary for me to grind on my nosecone. After it was in I thought that maybe I had done it unnecessarily, but maybe I did need it because mine looked like yours on the nosecone before grinding. Either way, mine works, and Im glad you got yours working.
How do you like it compared to the original?
roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
