Re: What did I do wrong on my ministarter
[Re: Commando1]
#968562
04/08/11 09:44 AM
04/08/11 09:44 AM
Posts: 15,487 Florida
scratchnfotraction
It just hit me that its a 4-speed all mine have been auto got a pic of where your doing this grinding at? block? starter? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: scratchnfotraction]
#968563
04/08/11 11:34 AM
04/08/11 11:34 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
My 65 with 440 has a scattershield and remaned mini.No grinding and it been in at least 10 years.The kids 62 300 has a Source min and fit perfect.Rocky
Chrysler Firepower
[Re: MonGoo$e]
#968564
04/08/11 12:07 PM
04/08/11 12:07 PM
Posts: 1,381 Youngsville, NC
dem440c
Youngsville, NC
Personal preference I guess but I think the mini starters are better than the stock starters in every way possible. They spin the engine faster, sound better, disengage and stop almost immediately (no waiting for the thing to wind down and stop spinning if the engine didn't catch the first time), are lighter, smaller, more clearance to the exhaust, and as I will explain below are cheap and long lasting if you buy the right ones. I have (no lie) at least 10 mini starters currently in use on both small and big block engines. The big block ones I just pop off that extension thingy and they fit fine, no grinding.
As far as where to get them- I bought one from MP years ago and it crapped out, I've bought a couple from parts stores over the years and one of them crapped out (replaced under warranty and still working today), but most of them I get from a pick n pull yard for around $20, find them on 90's era v8 truck and van (used factory units). These are the freakin shizzle as far as I'm concerned, they seem to work forever and they will whip a hot or high compression engine over no problem. Nuts to the expensive store bought pieces.
For the O.P., try disassembling it and check that the internal connection from the main electrical power lug is connecting to the solenoid. It should split internally to send power to the main body windings and the solenoid. Try jumping it there to see if it pops the pinion plunger out. It's either the connections or the solenoid itself, it's not real complicated to figure out once you see how it is constructed.
[Re: 69L78Nova]
#968565
04/08/11 12:59 PM
04/08/11 12:59 PM
Posts: 2,530 Nunya CA
CR8CRSHR
Nunya CA
That's why I use the stock boat anchor starters on everything.....plus they sound better than those new ones
I would have to disagree with you on this one. The stock "Boat Anchors" require more current draw and perform less effectively than the mini-starters. I won't even touch the fact that header interference with the stock starters is a PITA. Come on...step up to the 21st century and start running those mini's.... ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: CR8CRSHR]
#968566
04/08/11 01:06 PM
04/08/11 01:06 PM
Posts: 18,160 Mass
DAYCLONA
Mass
I've got 3 minis, SmBlk and BigBlk, Auto, 4spd factory bell, Keisler Bell, all running PowerMaster minis, no mods, no grinding, bolt on ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: therocks]
#968567
04/08/11 01:08 PM
04/08/11 01:08 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
I've used junkyard ministarters on /6,sb and big block with 130/143 Lakewood scattershield with 130 tooth flywheel and 143 tooth flywheel and never had to grind on the starter.
[Re: CHRGR69]
#968569
04/08/11 01:17 PM
04/08/11 01:17 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
It's interesting that some had to grind and some didn't need too. I had to grind a little on my 440 block with an Ultra bell in front of my 2 wire 518. Stock mini from newer a 92 1 ton van. It fit the Ultra bell just find. It didn't take much grinding on the block though.......just in the u shape part of the block around the starter.
Moparlee
#968570
04/08/11 01:38 PM
04/08/11 01:38 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
block? starter?
Hogged away a lot on the block around the starter housing area. Still too snug for comfort in my opinion but I didn't want to poke into a water jacket. Also did some light grinding on the stater, but I'm afraid to go too crazy on it.
[Re: dOc !]
#968573
04/08/11 03:18 PM
04/08/11 03:18 PM
dartman366
Mt. Vernon, Ohio
For what it's worth, I had to change out the dinosaur starter on the motorhome last summer, keep in mind it has header's on it so it is not an easyjob to change, got a mini starter from a 80's(i think) dakota tried it and it would not fit for crap, hit the block and the terminals were in the wrong spot' 1 mounting bolt would not engage the thread's ,,took it back to Car Quest and exchanged it for a 90's full size 360 truck and fit like a glove, can even snake it thru the headers to swap it out, and it looks just like the one on the race car that I bought from Mopar Performance years ago, maybe you are using the wrong style. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: dartman366]
#968575
04/08/11 08:06 PM
04/08/11 08:06 PM
Commando1
Hmmmmmmmmmmm.... Let me check this out more. I thought a mini starter was a mini starter... You just jarred a few ancient memory cells. Wasn't there a Denso and a Nipon-sumthing?
___________________________________________
Damn C1 ...doesn't ANYTHING go-right ferr U ? ...
Just another day in my wonderful life. ![](/ubbthreads/images/graemlins/eyes.gif)
[Re: NITROUSN]
#968577
04/08/11 08:35 PM
04/08/11 08:35 PM
Commando1
To have that much starter trouble something cant be right. Are both bell dowels in place? If they are missing or even one that could be the reason the starter fits poorly and the others short lived. Auto or manual tranny?
Dowels??? Ain't no stinkin (alignment) dowels. Manual tranny.
PLUS, now I'm really $%$# off. The top pic is the mini starter from Amazon - $72 The bottom pic is my Mancini unit - $129 ![](/ubbthreads/images/graemlins/eeek.gif)
Absolutely no one to blame except myself.
![](http://i51.tinypic.com/2mcbrdx.jpg)
