Page 3 of 3 1 2 3
Re: Does my crank need a pilot bushing or bearing? [Re: bboogieart] #966751
05/19/11 04:44 PM
05/19/11 04:44 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
i think the bearing you need is available direct from chrysler
part# 53009180ab
Re: Does my crank need a pilot bushing or bearing? [Re: rhad] #966752
05/21/11 05:52 PM
05/21/11 05:52 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I took the picture and the numbers listed on the replies to an Advance. The number on the bearing in the picture is a National number, it pulled up, picture looked right, it was in the warehouse and will be here in the morning. I should have time to pick it up and install it before I fly out tomorrow. I will up date once I do it.
Careful, your character's showing!
Re: Does my crank need a pilot bushing or bearing? [Re: mopar346] #966753
05/21/11 09:05 PM
05/21/11 09:05 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I ordered the same bearing from the dealer (my parts guy couldnt get the national one) and installed it last night when I went to go dial in my bellhousing (was lucky that it was within spec with the stock dowels) and i test fitted the transmission with it. It fit, but just barely, so i got lucky in that i dont have to chop the input shaft
Re: Does my crank need a pilot bushing or bearing? [Re: mshred] #966754
05/22/11 01:02 PM
05/22/11 01:02 PM
mopar346 Offline
mopar346  Offline
Picked up the bearing this morning, went in easily and the tranny slide right up no issue. Solved, on to other things.
Re: Does my crank need a pilot bushing or bearing? [Re: mopar346] #966755
05/22/11 02:04 PM
05/22/11 02:04 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
good to hear it worked out for both of us
So im assuming you didnt have to chop the input shaft either
Page 3 of 3 1 2 3
