Re: Which alum. intakes have 318 ports [Re: Kern Dog] #964984
04/03/11 06:00 AM
04/03/11 06:00 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
One of those 80$ pressure blasters OUTdoors ......ONE bag of silica sand for both intakes.
Re: Which alum. intakes have 318 ports [Re: dOc !] #964985
04/03/11 06:44 AM
04/03/11 06:44 AM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
Hey I have done a few 318,s and the streetmaster works fine with a Holley 600 or 650 ,I also put the stock 340 cam in them and the J heads with 188 intake and 160 exhaust valves , and even the newer 302 heads(last three casting number not a ford head) with the streetmaster . always there is one on ebay for around $100.00 plus shipping.
Re: Which alum. intakes have 318 ports [Re: mosweethemi] #964986
04/03/11 02:20 PM
04/03/11 02:20 PM
scratchnfotraction Offline
a 318/360 performer has the larger 360 runner but necks down the last 1.5 inches at the head port
I have used a porting kit to open it up to a 360 size port gasket matching them
only had to go into the port the 1.5 inch or so
I think the LD4B I have does the same thing..not 100% sure though,but it is for the 318 heads
the street dominator is another small port low rise single plane intake that works well on a 318 head
I have never seen an sp2p that was good for anything other than to choke one down,great if you idle around town and never get over 3000rpms
Re: Which alum. intakes have 318 ports [Re: scratchnfotraction] #964987
04/03/11 04:56 PM
04/03/11 04:56 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I know for sure the Eddy Streetmaster has small ports.I had one on the kids truck before he sold it.Now it sits in the garage.We used a Holley on the 318.Thats why we took the StreetMaster off.Rocky
Chrysler Firepower
Re: Which alum. intakes have 318 ports [Re: scratchnfotraction] #964988
04/03/11 05:21 PM
04/03/11 05:21 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
scratchN .... before you go N' the SP2P and sayN' it is no good after 3,000 ..... CHECK yurr own combo ...and clean-house ...
YOU and yerr log exh mans and that DINKY air-cleaner ...
....back atcha' !
Re: Which alum. intakes have 318 ports [Re: dOc !] #964989
04/03/11 05:36 PM
04/03/11 05:36 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The DOC is in the office! Whats the prescription?
Re: Which alum. intakes have 318 ports [Re: Kern Dog] #964990
04/03/11 07:11 PM
04/03/11 07:11 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
" polyester fumes"
I am truckless..
Re: Which alum. intakes have 318 ports [Re: 340SHORTY] #964991
04/03/11 07:27 PM
04/03/11 07:27 PM
I have a streetmaster on a DD 318 & even tho it has very small ports/plenum it is a single plane & wondering if a SP2P or an Offy dual port would better enough to search for one (Scratchn highly recommended the offy so I'm going to find one) but after incredibly poor mileage from it (speedo is inop) I found one of the Adel type clamps on the alum fuel line, the edge of the inner neoprene insert in the ID of it had shifted & the metal outer band had rubbed a hole in the line and the only way I caught it is it got to where I smelled the gas. I just bought headers/pistons and a Moped to ride to work while I rebuilt it
Re: Which alum. intakes have 318 ports [Re: RapidRobert] #964992
04/03/11 07:51 PM
04/03/11 07:51 PM
Nashport, OH
chargers777 Offline OP
Nashport, OH
I just found a weiand x celerator on crigslist local for 60.00.I didnt buy it because its a single plane and looks all wrong for a 318 in a heavy car.Do any of those alum. intakes work with a/c?Thanks for the help.Lots of good info here.
Re: Which alum. intakes have 318 ports [Re: chargers777] #964993
04/03/11 07:58 PM
04/03/11 07:58 PM
Between Houston & Galveston TX
SattyNoCar Offline
Happy Birthday SattyNoCar  Offline
I have an SP2P on the 318 in my 4dr:
The compressor looks like it has all its factory mounts in place (the intake was on the car when I bought it)
John
Re: Which alum. intakes have 318 ports [Re: 340SHORTY] #964994
04/03/11 08:20 PM
04/03/11 08:20 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Yes ..... there is someone who is very short, has 100 cubic inches LESS than a 440 ....and is a NUT !
THAT beez my Rx !!
Re: Which alum. intakes have 318 ports [Re: chargers777] #964995
04/03/11 09:00 PM
04/03/11 09:00 PM
Do any of those alum. intakes work with a/c?.
My small port SB street dominator alum intake has a threaded boss for the A/C bracket directly behind and several inches rearward from the front DR bolt hole same as an iron 2bbl SB intake I have
Re: Which alum. intakes have 318 ports [Re: chargers777] #964996
04/04/11 11:23 AM
04/04/11 11:23 AM
Cincinnati, Ohio
chargincharles Offline
Cincinnati, Ohio
Until I swapped a set of Magnum heads onto it I was running a Weiand xcellerator with a 340 AVS carb and 1 inch 4-hole spacer on my 82 Chrysler New Yorker. Ran great with this set up. But not drilled for the Magnum heads, so off it came.
And it doesn't get much heavier than an early 80's luxo-barge M-body!
Heres a link:
http://www.dippy.org/forum2/index.php?topic=4129.0
CC.
