Re: What will it run? 440
[Re: Evil67]
#963699
04/02/11 02:51 AM
04/02/11 02:51 AM
Posts: 1,165 Central Ohio, USA
Bigbeep
Central Ohio, USA
I think it needs a little more gear and maybe a little better intake. My brothers scamp has a mild 440, .030" cast piston, decked block, home ported 346 heads, 509 cam, team G intake, tci street fighter converter, 4.10 gear 26x8 m/t slicks best et 11.48
[Re: Evil67]
#963701
04/02/11 03:11 AM
04/02/11 03:11 AM
Bigbeep
Central Ohio, USA
BIg Beep - that is the baddest pic on here!!! That ole Cuda leaves like a B____!!!!
Thanks, I hope to get it back together soon. Cracked the block last fall and still deciding what to do. But Thank You. Beep
[Re: Bigbeep]
#963702
04/02/11 04:59 AM
04/02/11 04:59 AM
Posts: 1,596 BX, CT, FL.
B1KILLER
BX, CT, FL.
U should go 11.75, the glide will take away from u with that Small gear ur running , with my glide in my Valiant it Worked best with 4.88's, but I was running a totally Different set then U, good luck with it.
[Re: B1KILLER]
#963703
04/02/11 05:15 AM
04/02/11 05:15 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
That combo is absolutely begging for a plate system!!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#963704
04/02/11 05:22 AM
04/02/11 05:22 AM
B1KILLER
BX, CT, FL.
X2
[Re: SLOW67]
#963705
04/02/11 09:01 AM
04/02/11 09:01 AM
Posts: 2,611 Elbridge, NY
Dart1031
Elbridge, NY
I might have the best car here to compare yours to. My Valiant with an aluminum head 360/727 and 8 3/4 weighed 2,940 without me. With an iron head 440/727 and Dana it weighs 3160 without me. The 8 3/4 had drums, the Dana has discs. The 440 is a stock '78 short block with unported 906's milled to 80cc. It's got a .557 solid, M1 and a 950HP. I've had a Holley SD and a Torker II on it and there isn't much difference in ET on MY car. They were all within a tenth, all with the same 4 hole spacer. No mods done to any of them either. It runs the best shifting at 5,500. I tried all the way to 6,500 and it didn't make a difference. This certainly isn't the best combination of parts, but it was built years ago on a budget, lol. It's got a 4500 stall converter, 4.10 gears and a 28" Hoosier QTP. It has gone a best of 11.49/7.20(not on the same pass). It seems to be better in the 8th than the quarter for what it is. I've been told it would go quicker with a 509 cam. If you go that route, find an older used one that was broke in right. The new ones suck. I had one wipe out a lobe after only 8 miles on it! Hope this helps some
[Re: MoparBilly]
#963707
04/02/11 10:47 AM
04/02/11 10:47 AM
Posts: 928 NC
SLOW67
NC
I've got a 125 plate in the closet All I need is a bottle
[Re: SLOW67]
#963709
04/02/11 05:01 PM
04/02/11 05:01 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Getcha a bottle & drop it on, there will be no more second guessing if it'll run 7.8s in the 1/8 .
[Re: SLOW67]
#963710
04/02/11 05:48 PM
04/02/11 05:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'd be happy if I could get 7.80's out of it with the 3.55's. I plan on going to a 4.10 or 4.56 after I get the engine in the car and everything worked out....I don't want to spend all my money before then lol
I think it'll go a 7.90 in the 1/8... the trans and gear will kill the 60'.......... JMO
[Re: MR_P_BODY]
#963711
04/02/11 06:32 PM
04/02/11 06:32 PM
Posts: 928 NC
SLOW67
NC
I'm probably going to stick with the 727 for awhile, I don't want to track down another BB ultra bell after trading mine for a SB one...again
