Re: Hood pad clips...what a PITA... Suggestions? [Re: A12] #963582
04/30/11 04:44 AM
04/30/11 04:44 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i don't like the look of the pad anyway, now this new pad is taking up space in the garage!
Re: Hood pad clips...what a PITA... Suggestions? [Re: Scatransit] #963583
04/30/11 09:58 AM
04/30/11 09:58 AM
Arizona
az426john Offline
az426john  Offline
Arizona
My method of installation is to put a little bit of 3M yellow snot adhesive on the end, and then tap gently with a piece of 3/4 inch furing strip & a hammer.
I let the 3M adhesive cure a little while to get a skin on it so that I do not have it all over the place.
It works most of the time and they generally do not fall out everytime the hood is closed.
Good luck...it really is a PITA and no one really does a good job of reproducing them IMO.
Re: Hood pad clips...what a PITA... Suggestions? [Re: az426john] #963584
05/04/11 11:41 PM
05/04/11 11:41 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
I've had good results getting them for my '67 and '65 from junkyard cars, like $5 for a handful. A bit rusty, but fixed that with some homemade rust remover and followed up with Eastwood phosphate brew. The molded repop pad for my '67 took all of 15 minutes to install.
Maybe I should start flippin' insulation pad clips?
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
