Re: 340 Stroker cam Recommendations?
[Re: Brian Hafliger]
#963125
02/03/12 04:49 PM
02/03/12 04:49 PM
Posts: 69 Menomonie,wi
menomoniemopars
Menomonie,wi
I recommend our 251 cam: 251-260@ .050, .580-.560 lift with 1.6 rockers, on a 108lca. With an unported eddy head it should make around 460-470Hp with 10.2:1 compression, 750 holley DP, rpm intake with a 1" open spacer and TTI or similar header. With porting it can make 520+HP! Brian
Brian Do u have any video of a 416 running this cam? How it sounds etc?
