455 ci. Small Block
#962447
03/30/11 02:37 PM
03/30/11 02:37 PM
Posts: 513 HOUSTON,TEXAS
FIREGUY12
HOUSTON,TEXAS
Hey moparts. I have an engine I purchased from a member here on moparts. And wanted to know is there a better cylinder head I can purchase other than the B1/ BA M/C head that currently on it. The engine is 455ci 4.25 crank billet 4.125 bore 12-13:1 comp 620 roller R3 siamese 59 degree block. Dyno sheets states it made 630 H.P. 650 ft. lbs of torque. I have not run it in my car but know I want more power in the near future. Will an Indy or W-9 head pick up horsepower level. I would like to see 750-800 H.P.
Re: 455 ci. Small Block
[Re: FIREGUY12]
#962448
03/30/11 03:05 PM
03/30/11 03:05 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Id call Ryan J see what he says.. My good buddy runs a W2 iron head 420 inch engine... No dominator, no roller.. made 630hp on the dyno.... Runs 6.20's in the 8th mile at 108-110 mph in a mini tubbed dart with cal tracks.... about 2900-3000 lbs car. So yea Id say there is power in there somewhere.. if he can make his run like that... You know those B1 heads can make a good amount more done right. Clancy's car... . ![](http://i93.photobucket.com/albums/l45/The_Dakota_Kid/IM001951.jpg)
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#962449
03/30/11 05:33 PM
03/30/11 05:33 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I think a set of 245 cnc indys would get you in the 750 range. I made 650 or so with them 422 12.0to 1 4150 950 hp carb and 662 roller.More cubes,cam,compression I wouldn't see why you couldn't make that kind of power.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: BLONDE BARRACUDA]
#962451
03/30/11 07:30 PM
03/30/11 07:30 PM
Posts: 11,733 Portage,michigan
B3422W5
Portage,michigan
that moved center head should make way more than 630 horsepower, if that is what it is making now. i know ported they go around 350 cfm, as much or more than a big indy head. numbers are just numbers of course. That said, dont know much about that head, as not many are out there, but " in theory" it should make 700 horsepower easily. think they had like a 2.15 intake valve if i remember correctly. i know the much smaller b1ba head will make the kind of power this motor you are talking about currently, does.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
#962456
03/30/11 09:09 PM
03/30/11 09:09 PM
Posts: 11,689 W. Kentucky
justinp61
W. Kentucky
6.2 eighth mile at 110 doesnt sound like 630hp in a 3000lb car or so Ive been told. mine runs 6.15 at 111 eighth mile at 2985 and people tell me that is only 550hp
The calculator on Wallace Racing puts you at 650-665 flywheel hp.
[Re: FIREGUY12]
#962459
03/30/11 11:33 PM
03/30/11 11:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a couple of questions for ya... whats all the specs on your cam and what do you turn this up to (on the dyno since you havent run it yet)... those are usually a nice head.... 620 lift really says nothing ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#962460
03/30/11 11:39 PM
03/30/11 11:39 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I'd run it first..
If it were mine I would plug the lifter holes. Rebore and hone for 48 degree lifter angle.
Call CFE for the badest W8 he can put together for it.
Cause most of the guys who have these heads are not selling them off their engines. LOL
[Re: Leon441]
#962461
03/31/11 07:19 AM
03/31/11 07:19 AM
Posts: 1,019 Finland
mafo
Finland
That depends of course, how much is offered... ![](/ubbthreads/images/graemlins/biggrin.gif)
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: dusturbd340W5]
#962463
03/31/11 10:42 AM
03/31/11 10:42 AM
Posts: 660 San Diego
formula S
San Diego
I think some one is telling you wrong my 416 with indybrocks push my 3000 ride to 6.2x's at 110-110 in the 1/8 and its been 9.76 at 138 1/4 and every calculator I have put the numbers in is right at 620 hp at the flywheel.
FWIW Those calculators give you average horse power on a pass, not peak ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: FIREGUY12]
#962465
03/31/11 10:54 AM
03/31/11 10:54 AM
FIREGUY12
HOUSTON,TEXAS
Sorry I cant get the dyno sheet to post but, it was pulled to 6500 rpm. made peak 634 H.P. at 5700 Rpm, 650 ft. lbs. torque at 4600 rpm.
