Re: Holley tuning help
[Re: joedust451]
#962271
04/02/11 10:23 PM
04/02/11 10:23 PM
Posts: 1,100 Fort Lauderdale
Dave440
Fort Lauderdale
I think you will have to richen up the transition circuit to cover up the hole between the accelerator pump shot and transition into the main circuit. Usually enlarging the idle restriction and maybe the power valve restriction in the metering plate by a few thousandth should help
I would agree with those mods...EXCEPT...this isn't the motor that carb is going to end up on...(assuming the 650dp is goin on the 340 when its done? I could be wrong in ASSuming there) ...plus its a one way street if you drill the PVCR larger and it doesnt fix the problem or worse...end up drilling too large and it results in a rich condition. Or ends up fixin the problem on the 318 and it doesnt run right on the next motor it goes on. Then your stuffing bent pieces of wire in the pvcr to try to reduce the flow thru an oversized hole or buying a new metering block...etc...
I always like to start with external easily reversible changes like accel pump adjustments, plastic cam changes and engine timing FIRST.
Its also possible the PVCR size is fine but it needs a power valve that opens sooner than the stock 6.5. Maybe an 8.5 or 10.5 depending on engine vacuum at idle and cruise. Its all trial and error....and can get expensive parts wise but if youre stickin with Holley carbs then you end up with a collection of parts you can use to experiment with on most 4150 series carbs in the future (power valves do eventually get hard though- ive got a collection of petrified valves).
As for drilling...I only go drilling idle bleeds, fuel bleeds and PVCRs as a last resort...and its usually bcus the carb selection was wrong.
I'm also guilty of the "spending lots of time tryin to make carbs and manifolds you have lying around work right" scenario than I'll ever admit too. Oh mannnnn I just did.... DOH!!!! ![](/ubbthreads/images/graemlins/rant.gif)
Make adjustments, change parts...or drill baby drill... I guess it all depends how much time, money and patience you have ![](/ubbthreads/images/graemlins/wrench.gif)
As always.....YMMV
[Re: 451Mopar]
#962273
04/03/11 02:27 AM
04/03/11 02:27 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
I tried the larger squirters with limited success. To start, jet that puppy bigger 2 to 4 sizes per jet (primary and secondary) if the problem gets less, you need more fuel from the accelerator pumps. I believe the 650 comes with 31 nozzles standard. Going bigger doesn't help as the 30 cc pumps don't have enough volume per stroke to spray the fuel in as it is needed. I put dual 50 cc pumps on mine with 31 nozzles and I used the brown pump cam, turned it so it was about to push the accelerator pump lever, marked it and drilled my own hole. Hesitation went away for me. You need more fuel, the manifold is fairly big for that combo, it has no exhaust crossover to heat anything so it needs more fuel. This is all assuming the engine is happy and the carb is as well.
[Re: joedust451]
#962276
04/03/11 01:03 PM
04/03/11 01:03 PM
Posts: 538 PA
maxwedge1
PA
having been down this road before putting a hirise dual plane and vac secondary 600 on a previous stock 2bbl with 2.76 gear. It killed the off idle and bottom end.
assuming the carb is ok..my cure was alot of time experimenting on initial timing the idle mixture and timing curve. getting a clean idle with alot of initial and lighter spring for quicker advance was the fix but you have to deal with pump gas and pinging issues also if your to agressive.
need to limit total advance also since alot of initial and the lite springs will put total to high.
more gear would help if you are running "hiway" gears now.
[Re: maxwedge1]
#962277
04/08/11 11:00 PM
04/08/11 11:00 PM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
Havnt had a chance to work on the truck for a while but I found out that the miss and hesitation up top was from when I found out that I forgot to hook up the vacuum advance back up and then after hooking it up I checked the timing again and the total was at 52 degrees. Guess Ill have to lower the initial a little to get it back down.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
