Re: started new engine only 5-10psi oil pressure????
[Re: 64dartsb]
#961436
03/29/11 12:36 PM
03/29/11 12:36 PM
Posts: 2,930 Odessa, Tx.
cudarex
Odessa, Tx.
ok... I understand now. I'll get the solid lifters from crower, they aren't barbell type and they have a little oil hole at the bottom that I liked too. I should have just gotten those from the begining. I paid like $150 for these crappy 273 lifters too... I do everything twice no big deal...
thanks guys
Check your PR length when changing brands of lifters.
[Re: 64dartsb]
#961438
03/29/11 01:27 PM
03/29/11 01:27 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Before buying new lifters or doing any changes you should make an effort to verify the problem.. I'd suggest pulling the distributor & oil pump drive shaft then use a priming shaft & an electric drill to try pressurizing the oil system, first try seeing to galley plug perviously mentioned down through the distributor hole... If no problem is found there pull the oil filter & make sure the plug is installed... If you still haven't found a problem put the intake & give the lifters a good look, run the drill & turn the engine over, if a passage is opening you'll either see oil pouring into the valley area or pouring over the camshaft... If you still haven't seen a problem pull the timing cover & see if the galley plugs are installed up front.... Why buy lifters if they aren't your problem... They do work well with smaller cams & they are light.... BTW what are your cam specs...
[Re: 64dartsb]
#961440
03/29/11 04:17 PM
03/29/11 04:17 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
FWIW the oip pump drive is a 5/16 hex... MP still sells the tool pretty cheap.. http://chucker54.stores.yahoo.net/oilpumprimto.htmlBut I've seen it posted that you can get one of those paint stirring attachments for your drill & knock the fan blades off & have the same thing... Either way will work... Good Luck with it!!
[Re: 1_WILD_RT]
#961441
03/29/11 04:21 PM
03/29/11 04:21 PM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
Check your cam and lifters carefully, There's a chance you have no lobes left after starting without priming and low oil pressure. Ask me how I know.
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
[Re: Dave Watt]
#961442
03/29/11 05:13 PM
03/29/11 05:13 PM
Posts: 8,165 Left Coast
BobR
Left Coast
There is also a lifter galley plug next to the distributor gear which can be viewed with the distributor removed. It will bleed oil like crazy. Don't ask me how I know.
Been there/done that myself.
[Re: 64dartsb]
#961445
03/31/11 09:16 PM
03/31/11 09:16 PM
Posts: 363 San Diego
64dartsb
San Diego
I primed it and right by the lifters a bunch of oil was coming out. I changed it to some crower ones I bought and the leaks went away and oil pressure went up to 75psi ![](/ubbthreads/images/graemlins/punkrocka.gif) thanks
if your dreaming of your car then it's your dream car....
[Re: 64dartsb]
#961446
03/31/11 10:49 PM
03/31/11 10:49 PM
Posts: 52,972 Romeo MI
MR_P_BODY
thanks
Did you roll the engine over while priming.... at least a few revolutions ... glad you found your issue ![](/ubbthreads/images/graemlins/wave.gif)
