Re: Subframe connectors, which way should we
[Re: BADBEE]
#982
01/19/04 04:53 PM
01/19/04 04:53 PM
Posts: 3,336 Summit, NJ
whiplash
Summit, NJ
wow talk about back from the dead...
Since this post, I welded mine in 90° to Zippy, no floor pan welds, and boy what a difference it makes!! I'll post some pics because of they are similar to Tims:
- 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
- 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
- NEW BEST ET - 12.40@110mph...
[Re: whiplash]
#983
01/19/04 04:54 PM
01/19/04 04:54 PM
whiplash
Summit, NJ
[Re: whiplash]
#984
01/19/04 04:56 PM
01/19/04 04:56 PM
whiplash
Summit, NJ
[Re: whiplash]
#985
01/19/04 04:57 PM
01/19/04 04:57 PM
whiplash
Summit, NJ
[Re: whiplash]
#986
01/19/04 04:58 PM
01/19/04 04:58 PM
whiplash
Summit, NJ
five... check the emergecy brake cable...
[Re: whiplash]
#987
01/19/04 05:00 PM
01/19/04 05:00 PM
whiplash
Summit, NJ
[Re: BADBEE]
#989
01/19/04 05:29 PM
01/19/04 05:29 PM
whiplash
Summit, NJ
Single piece. Straight, no bends. I think Tims is ine piece, but he just cut a triangle out and bent it closed/welded shut the hole so the back of the bar angled up.
[Re: BADBEE]
#991
01/19/04 06:09 PM
01/19/04 06:09 PM
Thanks to Ma Mopar the floor pan on '65's B Bodies is nice and flat. No reason to cut the floor pan(s) to recess the subframes when the rear subframe is on the same plane as the floor pans.
#992
01/19/04 06:12 PM
01/19/04 06:12 PM
Floor pan at rear sub-frame, with connector welded in place Max
#993
01/19/04 07:00 PM
01/19/04 07:00 PM
Posts: 17,878 S.E. Michigan
ZIPPY
S.E. Michigan
Good evening ladies and gentlemen, and welcome to the post that wouldn't die! Glad to see it's still worth discussing, and good to see more jumping on the bandwagon and getting it done.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#994
01/19/04 07:36 PM
01/19/04 07:36 PM
here's some old pics of mine...
#995
01/19/04 07:37 PM
01/19/04 07:37 PM
#996
01/19/04 07:37 PM
01/19/04 07:37 PM
#997
01/19/04 07:38 PM
01/19/04 07:38 PM
#998
01/19/04 07:39 PM
01/19/04 07:39 PM
