Re: 727 - pulls motor down on 2-3 shift [Re: boscosis] #960935
03/29/11 12:22 AM
03/29/11 12:22 AM
Shifter alignment is perfect so I'm pretty confident that isn't the problem.
I've seen long time mopar drag racers get the adjustment off two turns of the cable end and not have a clue what was wrong, these are long time racers that have been around the block several times Think about how the bolt holes in the valve body are all (10)slotted so you can seat it with all the stock servo springs and such, move it 1/8 inch from one valve body to the next and your in trouble on the shifter adjustmenst on most aftermarket cable shifters I hate to see your freinds foot blown off because it is overlapping on the one to two shift
Re: 727 - pulls motor down on 2-3 shift [Re: Cab_Burge] #960936
03/29/11 08:32 AM
03/29/11 08:32 AM
boscosis Offline OP
super street
boscosis  Offline OP
super street
The 2-3 under WOT? Really nothing special - it seems to shift late (after the lever is pulled) and not quite as quick to change gears as it should be.
CAB - point taken and I appreciate the concern. We had just installed a new cable and my brother went to great lengths to check that its exactly where it should be. When we're ready to try again we'll check it very carefully for alignment.
Re: 727 - pulls motor down on 2-3 shift [Re: maximum entropy] #960937
03/29/11 10:27 AM
03/29/11 10:27 AM
Manistee, Michigan.
High Impact Offline
High Impact  Offline
Manistee, Michigan.
Just to add to the good advice given,
if that trans has a 5.0 front band lever, take it out and put a 3.8 or 4.2 ratio lever in.
yeah, that 5.0 lever is a killer. anything you can do to speed up the release of the intermediate band, is going to make it easier to nail down the 2-3 shift timing. a billet servo with heavy duty release springs is a good step.
I too put that 5.0 lever in my trans thinking it would make it a "killer shifting, tire chirping machine" It did that very thing where it bogged down going into 3rd gear, it just didnt shift right. I asked on here and was told to take that 5.0 lever back out and put in a 3.8. I did and it was perfect Then I cranked up my line pressure about 4 more turns and it shifts super. The best shifting mopar trans I've EVER had.
Re: 727 - pulls motor down on 2-3 shift [Re: High Impact] #960938
03/29/11 12:56 PM
03/29/11 12:56 PM
Wi.
65_gt_rag_402 Offline
Wi.
You are correct about the 5.0 lever. My dart has it in there and it shifts like that . trans is now 7 years old and never had a issue with it. Still shifts hard! That is the symptom you will get with a 5.0 lever. When you have it on the jack stands running , its more obvious .Nothing to worry about !
Darty
65 DART GT RAGTOP mopars "AWESOME" 360 magnum stoker 402 Engine !!!!!!! ROCKS !!!!!!!!!! 11.0's on pump gas .
