Re: 727 - pulls motor down on 2-3 shift
[Re: maximum entropy]
#960937
03/29/11 10:27 AM
03/29/11 10:27 AM
Posts: 1,562 Manistee, Michigan.
High Impact
Manistee, Michigan.
Just to add to the good advice given, if that trans has a 5.0 front band lever, take it out and put a 3.8 or 4.2 ratio lever in.
yeah, that 5.0 lever is a killer. anything you can do to speed up the release of the intermediate band, is going to make it easier to nail down the 2-3 shift timing. a billet servo with heavy duty release springs is a good step. --------------------------------------------------
I too put that 5.0 lever in my trans thinking it would make it a "killer shifting, tire chirping machine" It did that very thing where it bogged down going into 3rd gear, it just didnt shift right. I asked on here and was told to take that 5.0 lever back out and put in a 3.8. I did and it was perfect Then I cranked up my line pressure about 4 more turns and it shifts super. The best shifting mopar trans I've EVER had.
[Re: High Impact]
#960938
03/29/11 12:56 PM
03/29/11 12:56 PM
Posts: 334 Wi.
65_gt_rag_402
Wi.
You are correct about the 5.0 lever. My dart has it in there and it shifts like that . trans is now 7 years old and never had a issue with it. Still shifts hard! That is the symptom you will get with a 5.0 lever. When you have it on the jack stands running , its more obvious .Nothing to worry about ! Darty
65 DART GT RAGTOP mopars "AWESOME" 360 magnum stoker 402 Engine !!!!!!! ROCKS !!!!!!!!!!
11.0's on pump gas .
