Re: Can you guys rate my 383 build...
[Re: DaytonaTurbo]
#960668
03/29/11 10:07 AM
03/29/11 10:07 AM
Posts: 75,103 A Banana Republic near you.
JohnRR
You don't HAVE to run higher compression with the aluminum heads, just you are able to run a bit higher compression without detonating.
You can use the speedpros , you may have to cut valve reliefs in them, have the block cut so the pistons are at zero, have the heads cut to 80cc and you'll be at 10.0 , the flattop piston will be more efficient than the KB400 with a dome.
[Re: JohnRR]
#960669
03/29/11 10:19 AM
03/29/11 10:19 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I ASSumed the piston depth based off a measurement I took from the original pistons and then added the CH of the new pistons. I know I'm not going to know for sure until I get it back from the machine shop, which is why I haven't ordered the head gaskets yet.
I may go with headers, not sure which ones would fit or not. This is a manual brake, manual steering '68 Sat.
The gear is a 3.23 with a 2500 stall. That cam should be just a little larger than a stock HP cam, so I'm not sure why 10.5:1 CR is really needed?
I'm not going to be racing this thing at the drag strip. It's a pretty cheap car that I don't have much money invested in and felt like making something to cruise and go fast in every now and then.
I usung the Summit headers on my 440-6. They fit w/o any problems. Even when I had PS. I'm also using a mini-starter.
You shouldn't compare a 440 and starter clearance using a mini starter to a 383 , the headers are closer to the block on the 383. I TRIED to use a mini starter with a set of 1 3/4 primary headers and I couldn't get the header on the engine with a mini starter .
The Summit headers have a nice "flat" spot in them for the big old school unit. But why would you even use one of those unless you were doing a full resto show pony.
b4 manual steering
[Re: JoesMopar]
#960674
03/29/11 09:26 PM
03/29/11 09:26 PM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
Ok, I have parts, so this is pretty much the way the build is going to be, not much in the room of changing things around now...
I did as much research as I could....with the help of you guys
Anything with a "?" beside it is still not for sure...so I would need some input
383 .030 over std rod/mains ARP rod/main/head bolts Edelbrock closed chamber heads Cometic .027"/4.35" head gaskets (?) SpeedPro 2315 (1.920" CH) stock deck height (squared to crank) balanced assembly Comp XE 274/286 cam/lifters Performer RPM intake 650 Thunder Series Carb (?) MP igniton conversion kit Factory HP manifolds (?....any issue with the angled plug heads? would rather not use headers) Comp Double Roller
I'm getting 9.57:1 CR ASSuming the piston is .01 in the hole with the 2315 pistons. That would also figure a .037" quench as well....correct?
How does this sound to you guys?
MP has the Eddy head in a straight plug, but it looks like you've purchased the heads already.
Get the CR to 10:1 to 10.2:1
I too prefer zero deck and a 0.040" gasket. You'll probably save $ on the gasket too.
I too like the Crower 271 cam.
I would use more carb cfm
You definately do not need 3" exhaust. It will probably hurt performance.
[Re: BSB67]
#960675
03/29/11 10:21 PM
03/29/11 10:21 PM
Posts: 393 ILLinois
DartGTS
super street
super street
ILLinois
Hello: Lots of different opinions here, I'm not going to touch engine build.. best thing you can do for street performnce with that car is replace that 3:23 with a taller gear.... 3:91 (and convertor to match) if you don't do lots of highway interstate driving. That 3:23 gear with big cam not gonna be best stop light car.
My 2 cents. Maynard
[Re: DartGTS]
#960676
03/29/11 11:00 PM
03/29/11 11:00 PM
Posts: 2,782 USA
JoesMopar
USA
Ok, I am not building a race car, drag car etc. I am purposely building this thing to cruise, especially the interstate and highways. I appreciate the info on swapping converters, gears etc. But I'm not going to do that, it is what it is and I did it for a reason....I already have a car with a 3200 converter and "only" 3.55's. It revs too high on the interstate as it is....3200 RPM is too noisy for my liking.
My main concern is the heads/piston/head gasket combo. I wasn't aware when building a 383 that piston choices suck. Not only that, but it sounds like my options are expensive pistons or expensive machine work. I just so happen to have the expensive pistons....however from what most people on here tell me that the CR will not be enough with my head gasket choice (if I get it....027") and my head chamber volume (84cc). So I am back to thinking of just ordering a set of KB400s which from what I have calculated should be very close to 10:1...but I could be and probably am wrong.
Once I get info from the machine shop of what the depth will be with the KB400's vs the 2315's I'll make a definitive decision. Supposedly the KB400's will be inefficient compared to the flat top 2315's.....whatever that means.
The gear stays, the converter stays, the cam stays....I will probably take everyone's advice on the carb, maybe even consider headers after I get some miles on it and feel like doing something.
[Re: JoesMopar]
#960677
03/29/11 11:31 PM
03/29/11 11:31 PM
Posts: 1,647 IL
71383beep
IL
if your looking for just a cruiser the eddy heads are a bit overkill. You can get decent street manners of a similar setup with OE closed chamber heads like the 516 or better yet the 915 heads. I have 516's on mine with a bigger exhaust valve and the mopar .474 cam. With KB162s and some head work it is 9.2:1.
Also running a 650 mighty demon and the car moves rather nicely for a 3,800 purple beast. I don't care for the edelbrock carbs personally.
'73 GK6 Challenger Rallye - 340 4-Speed
[Re: JoesMopar]
#960678
03/30/11 08:18 AM
03/30/11 08:18 AM
Mr.Yuck
Brookeville, Md
if you are worried about compression use the steel shim gasket. IIRC it crushes to .019. If overall performance isn't an issue Grab a $70 summit cam and toss the thing together. It will run fine.
[Re: JoesMopar]
#960679
03/30/11 09:42 AM
03/30/11 09:42 AM
JohnRR
The CH of the KB400 is 1.908 , the CH of the 2315 is 1.920.
You should really call the cam company and get their recommendation for the convertor a cam/rear gear mismatch can be somewhat masked by a 4spd , not some much with a automatic trans. ... edit , I just went back and reread, your convertor choice may not be that far off especially if you go with the 268.
What I meant by inefficient is the dome impedes flame travel across the chamber , a flat top doesn't . I am building a 383 based stroker with 12.5 compression and the only way to do it was either cut the bleep out of the heads or use a small dome , I chose the dome , should have cut the heads
You didn't buy the EXPENSIVE piston , that is the Diamond. You could have had the block decked , mock it up and ordered a piston that didn't require cutting a mile off the block, that's what I did with the 383 engine that I just recieved from the shop yesterday. But my block had already been cut a mile because of bad first piston choice, the 2315, and then shoddy machining by a couple of shops this block has passed thru till the latest. It's a 10.0 build with open chamber iron heads.
Do what you want , you asked for people to rate your build , you got it and it seems you don't like some of the answers you are being given.
The steel shim gasket is .021, 65-75 ft/lbs is not going to crush it like it does with a composite gasket .
[Re: JohnRR]
#960680
03/30/11 10:28 PM
03/30/11 10:28 PM
Posts: 2,782 USA
JoesMopar
USA
What is the CH of a stock 383 piston? I can't remember but I thought it was less than the KB400 1.908.
I understand what you mean by the dome "getting in the way"....but how does that affect your car? Decreased performance? Gas Mileage? I was looking at getting the dome to help with CR since everyone was saying 9.5:1 wasn't enough for that cam. The dome would put it about 10:1.
[Re: 1_WILD_RT]
#960683
03/30/11 11:08 PM
03/30/11 11:08 PM
Posts: 2,782 USA
JoesMopar
USA
In a perfect world the flame front would progress faster across a flat piston than one w hills but a flattop piston w enough CH to get quench will most likely give you too high of CR plus you'll need valve reliefs machined. Get the KB's w the quench plateau & mockup/machine to get quench (.040" max) plus the right SCR for your app
The thing is the dome isn't on the side where quench is obtained, it's in the chamber area... To get quench you need a closed chamber head which I believe is what the O/P is planning to run... So at the point quench becomes a function of how far the piston is in the hole & head gasket selection.... There are no off the shelf quench dome pistons for 383's...
Exactly.
I know what you guys are saying about the flame travel....what I'm trying to understand is what does that mean in terms of performance? JohnRR mentioned he wished he would have cut the heads instead of using the dome.....what do you cuss about when driving your car that you think to yourself "I wish I would have cut the heads.."
I fully understand what quench is and the benefits. I also hear from you guys that the aluminum allows for a higher CR because of the reduced heat inside the chamber. @ 10:1 CR, do I need "perfect" quench when I'm using heads that supposedly give me the same effect as a 9-9.5:1 steel headed engine when I already plan on running 93 octane? In other words, with the reduced heat that you guys mention, will quench really play that much into any detonating problems @ 10:1 with aluminum heads.
[Re: JoesMopar]
#960684
03/31/11 12:13 AM
03/31/11 12:13 AM
Posts: 679 N.E Indiana
repad
super street
super street
N.E Indiana
Just want to share this with you, last year I rebuilt a numbers 69hp 383 for a super bee. I left it as much stock as the available parts would allow using the speed pro pistons .030 and the Summit cam/lifters which was very close to the original stock hp cam. Even used the original 625 carter carb and the hp manifolds. Stock original converter and 323 gears. Stock original 906 heads with stock valve sizes and springs. This is a sweet running engine with plenty of torque to light up the tires and a respictable high end. The idle is smooth and throttle response is crisp, just a great running engine for the street. To sum it up, the stock hp 383 is a respectable performance engine in its own right. I suggest a pair of headders for a nice 15-20 hp gain.
[Re: RapidRobert]
#960686
03/31/11 12:29 AM
03/31/11 12:29 AM
JohnRR
Robert , Robert , Robert , you appear to know NOTHING about 383's , you should sit back and LEARN from those that do ...
KB does NOT make a quench head piston for a 383 , never has and probably never will, so you need to stop suggesting that to people building 383's. Nevermind to get quench with a flat top and a closed chamber ... uuum , just zero deck , you zero deck and with 80cc head you end up with 10.0 , since the heads he wants to use are 84cc he's not going to have too high a compression ratio ??? It's not rocket science , the problem with a 383 and compression is the SMALL bore size and the SHORT stroke, combined it's hard to get decent compression.
[Re: JoesMopar]
#960687
03/31/11 12:38 AM
03/31/11 12:38 AM
JohnRR
Depends on the year engine but the stock CH of the 68-69 383 HP (which is what i base all my on ) , and 68-69 2bbl for that matter , is 1.932 , this puts the piston .0025 in the hole on a factory deck height, the 2bbl piston has a dish. as delivered the HP was 9.2 at best. I've gone 100mph in the 1/4 with a 56K worn HP engine with a timing chain so loose it could be removed without taking off the gears ... almost... so it's not as bad as we are lead to believe.
One of the mags did an article on installing ebrocks on a 383 , they THOUGHT they had a piston close to factory CH. But when they pulled the heads it had low compression cast replacements, they were something like .050 plus below the deck , the engine was not the DOG they thought it would be, food for thought .
In the grand scheme of things you will probably not notice any difference with the KB400 so just ignore what I said about inefficiency .
