Main cap broke in half ****UPDATE*****
#960069
03/27/11 05:48 PM
03/27/11 05:48 PM
Posts: 2,054 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Yep. Built this engine last winter and put close to 300 passes on it. Wasn't planning to do anything to it this winter, except fix the oil leak at the pan. My machinist talked me into at least pulling a couple of rod caps and check the bearings, so I pulled the engine, checked the rod bearings and all looked good...until I saw something "that just didn't look right". #2 main cap broken into 2 pieces. I am going to disassemble the rest of the engine this evening, hopefully everything else is OK. Anyone have any ideas what causes this? Stock block, crank and main caps, EVERYTHING else is aftermarket. Arp main studs, H beam rods, Ross 13.5:1 pistons, Milodon gear drive & SS oil pan w/ swinging pick up, Stealth heads, Team G intake w/ 1050 dominator, 2" Hooker headers, ect, ect. 1 week before 1st race, what are my options??? Thanks, Brian Dunnigan
Re: Main cap broke in half
[Re: '72CudaRacer]
#960072
03/27/11 06:09 PM
03/27/11 06:09 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Seen it happen several times. As for the cause,,,IMHO..when this happens, as you have said, with stock caps/crank/etc.,,,,you are pushing the envelope as they say, to the "limits". I would say the main cause is cap movement/flex. It is time for some good caps.
If you like drag racing, support your local track.
[Re: '72CudaRacer]
#960073
03/27/11 06:10 PM
03/27/11 06:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You need to pull it apart so you can see IF anything else has a issue but right now its a set of caps and a line bore... I've seen those BB crack a cap and the owner/driver didnt know when or how it happened... BB tend to do it... just my opinion... detonation
[Re: '72CudaRacer]
#960075
03/27/11 06:35 PM
03/27/11 06:35 PM
Posts: 43,308 Bend,OR USA
Cab_Burge
Is this a 400 or 440 block? In either case take the motor all the way apart and have the main webs magnaflux very thoroughly before preceeding If the main webs are not cracked then you have to decide on how you want to fix it, steel or aluminum main caps As far as why they break to start with I would bet on detontaion I've seen several 400 blocks break the main caps along with splitting cylinder walls at the same race That motor split the #2 cylinder and broke the #5 main cap The owner says that it never hydrauilic or treid to kickback like it was hydraulicked I would probally look at a set of Aluminum main caps, not the four bolt type either, in your motor if it was mine
[Re: Dodgem]
#960077
03/27/11 09:15 PM
03/27/11 09:15 PM
Posts: 1,443 Maryland
Dads426
Maryland
Brian,
If you want to keep the stock caps, I have a #2 that I can send to you for a RB block. Let me know. Jon
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dabee]
#960082
03/27/11 10:47 PM
03/27/11 10:47 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Tough break Brian... Sucks for sure....
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: 383man]
#960084
03/28/11 02:39 AM
03/28/11 02:39 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I should have a #2 cap (RB), if you need it.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Mr.Yuck]
#960085
03/28/11 09:27 AM
03/28/11 09:27 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Yuck I had a 70 Imp that didnt break the caps but did break a main bolt.I had low oil pressure also.It started to get a slight knock so I dropped the pan.Found the head of the bolt and the bolt in the pan.I probally drove it like that for 5000 miles before I pulled the pan.Now the block is in my 65 with ARP studs.The block that was in my 65 when we took it to the machine shop had a bent rod.Never had any problems even spinning it to 6K.My machinist couldnt believe it was running with that rod.Rocky
Chrysler Firepower
[Re: '72CudaRacer]
#960086
03/28/11 11:25 AM
03/28/11 11:25 AM
Posts: 7,506 Az
Crizila
Az
Great catch! You owe your machinist a . Probably detonation - The bearings might confirm it. Besides what's been mentioned, you might want to look at your fuel / timing situation. IMO, this is why it pays to leave a little on the table when it comes to staying out of detonation. Most aren't as lucky as you.
Fastest 300
[Re: earthmover]
#960088
03/28/11 06:02 PM
03/28/11 06:02 PM
Posts: 1,629 pa
572charger
pa
i got brand new billet caps for a 440 $100.00 jphemi68@yahoo .com
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
