Re: Atco Raceway - Monday May 2nd - Private Track Rental
[Re: JohnRR]
#959385
05/04/11 11:26 AM
05/04/11 11:26 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
Andy & Barry,,,,,LOOKIN' good ![](/ubbthreads/images/graemlins/thumbs.gif) Bob,the blood drippin' down the side of the car,,not good
thats not Bob...
restricted baffle in the vacuum pump caused that leak. here's the only video I have from the day
http://www.youtube.com/watch?v=PwLZz9tUqpg&feature=channel_video_title
You need to hire a new cameraman.
Fred I'm so glad you put a period correct scoop on the car.
At this point he needs a water and oil pump that work first...
[Re: DJVCuda]
#959386
05/04/11 02:10 PM
05/04/11 02:10 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
thats not Bob...
JOHNRR I changed the scoop because I had no choice. There was no way I could see anything with the tall cowl.
Dave if you would have read my post on the water pump problem it is a common problem being air bound and many here have had it happen. The pump is fine. Same as for the oil pump comment. posted the info in what you quoted restricted baffle in the vacuum pump caused that. Nothing wrong with pump. For a guy who was technical editor I would expect that you would have paid more attention. ![](/ubbthreads/images/graemlins/stirthepot.gif)
CONFUCIUS say:
"MAKE SURE BRAIN IS ENGAGED BEFORE PUTTING MOUTH IN GEAR"
[Re: HEMIFRED]
#959387
05/04/11 02:15 PM
05/04/11 02:15 PM
DJVCuda
Atco NJ
I can read - I can also break your balls Fred... ![](/ubbthreads/images/graemlins/grin.gif) Thanks for showing up late so everyone could get down the track before you gave it fine mist of oil... lmao!
Re: Atco Raceway - Monday May 2nd - PIX?
[Re: DJVCuda]
#959388
05/04/11 02:17 PM
05/04/11 02:17 PM
DJVCuda
Atco NJ
It's the Exxon Valdes! It's the gulf oil well leaking! NO!! It's HEMI FRED!!! ![](/ubbthreads/images/graemlins/pity.gif) lighten up francis...
[Re: JohnRR]
#959392
05/05/11 03:34 AM
05/05/11 03:34 AM
Posts: 4,086 Mo.
racerx
Mo.
thats not Bob...
Anyone know if it was a full past what ET/mph it run? I remember that car from the Lou. ![](/ubbthreads/images/graemlins/wave.gif)
[Re: racerx]
#959393
05/05/11 05:46 AM
05/05/11 05:46 AM
DJVCuda
Atco NJ
