Page 2 of 3 1 2 3
Re: 64 65 Max wedge valve covers. #959137
03/30/11 12:10 AM
03/30/11 12:10 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
That's a modified race engine, air cleaners, valve covers, 13:1 compression, fender well headers? etc. Not stock/original.
Re: 64 65 Max wedge valve covers. [Re: ScottSmith_Harms] #959138
03/30/11 12:22 AM
03/30/11 12:22 AM
Actually, it's the Ramchargers' Super Stock 61 Dodge.
Re: 64 65 Max wedge valve covers. #959139
03/30/11 12:26 AM
03/30/11 12:26 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
By the caption on the photo that's pretty obvious right?
Why did you post it as "Then there's this"? Were you thinking finding a vintage picture was some kind of evidence towards showing chrome valve covers on a factory engine or did you just think the picture was cool (which it is of course).
Re: 64 65 Max wedge valve covers. [Re: ScottSmith_Harms] #959140
03/30/11 01:02 AM
03/30/11 01:02 AM
Well, obviously at least one member of the Ramchargers liked chrome valve covers. . . .
Re: 64 65 Max wedge valve covers. #959141
03/30/11 02:23 AM
03/30/11 02:23 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Re: 64 65 Max wedge valve covers. #959142
03/30/11 10:09 AM
03/30/11 10:09 AM
Of course, there's always this, too:
I dunno, that cowl grille, firewall and engine compartment looks like a 62/63 to me!? But, like Scott said, it's modified...but cool!
Re: 64 65 Max wedge valve covers. #959143
03/30/11 10:33 AM
03/30/11 10:33 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
What year is that from?
Re: 64 65 Max wedge valve covers. #959144
03/30/11 10:45 AM
03/30/11 10:45 AM
You know, you're right. The 61 firewall would have a fiberglass heater box on the firewall (among other differences). The picture comes from the Chrysler Performance magazine shown above that I bought new in the summer/fall of 1962, and is right next to a picture of the Ramcharger 61 Dodge beating a 409 Chevy at Indy, but I never noticed before that it's not a 61 engine compartment. Looks like the inner fenders have been cut for clearance and the rest painted black. Maybe it's a test mule for the 62 max wedge package during development???
Here's a 61 Dodge engine compartment (this one's a short-ram 383):
Re: 64 65 Max wedge valve covers. #959145
03/30/11 11:20 AM
03/30/11 11:20 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That one has been "breathed on" as well, notice the cooling fins on the coil?
Re: 64 65 Max wedge valve covers. [Re: ScottSmith_Harms] #959146
03/30/11 11:27 AM
03/30/11 11:27 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
You can tell that because someone changed the COIL ???? or are you ASSuMEing it ?
Re: 64 65 Max wedge valve covers. [Re: JohnRR] #959147
03/30/11 11:43 AM
03/30/11 11:43 AM
central ohio
mopar rookie Offline
central ohio
What valve covers do I need for a Max Wedge clone using 440 heads. The valve covers I have have wire looms welded on them. Does anyone have what I would need?
Re: 64 65 Max wedge valve covers. [Re: JohnRR] #959148
03/30/11 11:46 AM
03/30/11 11:46 AM
The finned coil is part of the transistorized ignition setup. That photo is from an article in the October 1961 issue of Hot Rod Magazine, titled "Dodge's Hot Options," meaning basically parts not installed on the assembly line, but approved as NHRA legal stock and available from the dealer's parts department.
Re: 64 65 Max wedge valve covers. #959149
03/30/11 11:51 AM
03/30/11 11:51 AM
The other thing I noticed was it was a heater delete car!
It HAS to be a '62 or '63 Dodge/Plymouth B-body because the cowl grille is rounded vs. the flat style that the went to in '64.
Re: 64 65 Max wedge valve covers. [Re: ScottSmith_Harms] #959150
03/30/11 04:30 PM
03/30/11 04:30 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Chrome valve covers (6 holes) were available on the 67 GTX 440...
Just my $0.02..
No, they were standard on them, other post 66 cars had them standard as well (R/T's, big block A-bodys, etc.)
Partially correct..
Some were also painted on the mentioned models..
Just my $0.02...
Re: 64 65 Max wedge valve covers. [Re: Sinitro] #959151
03/30/11 04:43 PM
03/30/11 04:43 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Partially correct..
Just my $0.02...
Exactly which ones are you refering to? If you mean A-bodies, yes, it varied on those, but they were a standard as opposed to an optional item.
Re: 64 65 Max wedge valve covers. [Re: mopar rookie] #959152
03/30/11 05:04 PM
03/30/11 05:04 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
You need 6 bolt covers just remove the wire looms you do not need with a dremel .
Re: 64 65 Max wedge valve covers. [Re: JohnRR] #959153
03/30/11 05:29 PM
03/30/11 05:29 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And you'll probably have to do this depending on what rocker arms you use.
Re: 64 65 Max wedge valve covers. #959154
03/30/11 06:30 PM
03/30/11 06:30 PM
USA
max Offline
super gas
max  Offline
super gas
USA
They didn't have chrome air cleaners and weren't painted orange and blue, either, but they sure were pretty that way.
I actually had a set of chrome air cleaners a few years back that were from a late family friends 63 MW car. But I believe he traded the factory black ones in on them at the dealership when he bought the car.
Over the years I have read the chrome air cleaners were available in 1962 only for the MW cars.
Re: 64 65 Max wedge valve covers. [Re: max] #959155
03/30/11 07:23 PM
03/30/11 07:23 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
Re: 64 65 Max wedge valve covers. [Re: ScottSmith_Harms] #959156
03/30/11 08:28 PM
03/30/11 08:28 PM
dark side of the moon
Dougsmopars Offline OP
I saw this set advertised as 64 65 max wedge. I didn't think there were 64 maxies since the hemi was out. Was curious if maxies ever had chrome covers.
Page 2 of 3 1 2 3
