Re: How to Lower Your 1972-1993 Dodge Pickup
[Re: RodStRace]
#958169
03/27/11 07:47 PM
03/27/11 07:47 PM
Posts: 770 Central Utah
Mopargnome
Central Utah
I did the Dakota spindle swap on my Ramcharger and its not that big of a deal. I got cut coils on the truck control arms but want to swap for the van ones. Thanks for the info!
Dave, if you lower that thing another 3 inches with the van LCAs, you are going to have to put rubbing blocks on the bottom!!!
To do the van control arms I would have to put stock height springs back in it, therefore it would sit about the same height. Its either that, or airbag it.......
[Re: Mopargnome]
#958170
03/29/11 01:35 AM
03/29/11 01:35 AM
Posts: 440 Marysville, WA
77ProStreet
Marysville, WA
NICE JOB KEVIN! You did an AWESOME job writing all of this and explaining it with pics. A lot of us appreciate it very much, you have made it real simple. PS. I would like to see more pics of your truck, its darn near a twin to mine. Mark
[Re: 77ProStreet]
#958171
03/29/11 10:46 AM
03/29/11 10:46 AM
Posts: 718 Nunnelly, TN
Kevin I
Nunnelly, TN
NICE JOB KEVIN!
Mark
Thanks. How 'bout some pictures of your's? I will dig up a few pictures of the truck when I get home. Here is one to tide you over until then.
[Re: Kevin I]
#958172
03/29/11 01:41 PM
03/29/11 01:41 PM
Posts: 132 Oklahoma City, Ok.
73TruckGuy
Oklahoma City, Ok.
Nice info and good looking ride Kevin. My 73 was a learn as I go process with the help of Rumblebee, and a couple of other guys. I know now what I've done wrong, and as soon as I get back from MATS, I'm going to go through the front end... again! I've got mine sitting on 20x8s all the way around, and for all intent and purpose it LOOKS good. Even in the rust finish, unfinished state that it's in. But, I know the Van LCA's offer a somewhat smoother ride than my cut springs! But, as I said, learn as I go, and my dad, God Bless him, for setting himself on fire with the cutting wheels, cussing the rivets in the back, and then helping me replace the rearend after a minor mishap... We've found out though, that either we need taller jacks... or slimmer waistlines! Seeing yours makes me wanna get out there and shake the winter blahs, thanks Kevin!
[Re: stumpy]
#958175
03/29/11 09:36 PM
03/29/11 09:36 PM
Kevin I
Nunnelly, TN
I'm another one that used the dropped Dakota spindles on my 74 D100. I did it in one day in my driveway. Simple swap with no problems afterward. Even used stock D100 springs and still got 2.5" drop.
I guess it isn't as hard as I thought. I remember a thread on another forum a few years ago before it was all sorted out and there were a few issues the guy was trying to figure out.
[Re: Kevin I]
#958176
03/29/11 11:14 PM
03/29/11 11:14 PM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
One thing I have found though is that a lot of the 70s Vans had standard non-pocketed control arms. 80s though the majority I have seen are pocketed however. The standard ones do have both sets of strut rod holes drilled.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
[Re: MoPar Jamie]
#958177
03/30/11 12:35 AM
03/30/11 12:35 AM
77ProStreet
Marysville, WA
When I said "twin", I meant that mine is the ugly one! I will get a couple pics tomorrow. I'm in the process of getting all my parts together to do a quick lowering job. I already bought the drop spindles and was going to use the van LCA's with, but that might get me too low.
Is there such a thing as too low?
[Re: MoPar Jamie]
#958178
03/30/11 12:40 AM
03/30/11 12:40 AM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
What I have learned over the years was that 5 lugs or 8. As long as the lug stud diameter was 1/2" the ball joint is the same on the van. Big stud 3300# & larger requires drilling the spindle to bolt it correctly to the steering arm. As soon as I sit my RC on the ground again I'll post a pic of it & my lowered CrewCab. Kevin,I think your post is cool especially being this subject comes up very often.
[Re: BulletBob]
#958179
04/01/11 10:05 AM
04/01/11 10:05 AM
Kevin I
Nunnelly, TN
Thanks.
I am going to try to lower the rear tomorrow. Would it be a waste of time to do a similar write up for a rear axle flip?
[Re: BulletBob]
#958181
04/01/11 05:35 PM
04/01/11 05:35 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
There's 2 ways to do the axle flip! Bob
How do you figure?
[Re: 76dodgeboy]
#958182
04/01/11 08:59 PM
04/01/11 08:59 PM
Posts: 15,487 Florida
scratchnfotraction
right off there is the flip flop with shackle flip with front hanger then flop the axle on top of the springs then the long chebby shackles to keep the axle under the spring but not a true axle flip then the front hangers upside down with a shackle flip on the rear with an axle flop then just floping an axle on top of the spring with shackle and hangers in stock location get it were you want it then weld in ladder bars in line with the frame for the same ride hieght then remove springs and hangers from the outside of frame rails or what goose did with his hangers and axle flip adding blocks yea I say there are a couple ways to get-r-done
[Re: Kevin I]
#958187
04/02/11 05:20 PM
04/02/11 05:20 PM
77ProStreet
Marysville, WA
It's never a waste of time! There is always someone who has never done it, and needs a little guidence. Go for it Kevin!
[Re: 77ProStreet]
#958188
04/02/11 05:54 PM
04/02/11 05:54 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
it would be good info for someone wanting to know how to lower them and how to adj pinion angle after its done
