Re: Dist Drive Shaft Bushing to Shaft Fit
[Re: Bigbeep]
#957400
03/23/11 11:38 PM
03/23/11 11:38 PM
Posts: 3,480 Dandridge TN
Dabee
Dandridge TN
I have always knocked them in the block and used an old distributor/oil pump driveshaft with a helical type cut in the shaft. Acts more like a ream than a burnishing tool. The cut I made with a exhaust cut off tool and cut it in a spiral pattern like a drill bit. It has worked for me so far.
The shop manual specifically says in bold “DO NOT REAM THIS BUSHING”, but it doesn’t say why. This is an option though.
[Re: ahy]
#957402
03/23/11 11:42 PM
03/23/11 11:42 PM
Dabee
Dandridge TN
I borrowed the correct burnishing tool from a Dodge dealer I traded with quite a bit. I left a deposit but the tool did not cost anything to use.
That is one of the things I was planning on checking in the morning. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Dabee]
#957412
03/24/11 02:47 PM
03/24/11 02:47 PM
Posts: 26,044 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I will add my standard statement to this thread, "Doing it wrong and getting away with isn't the same as doing it right".
[Re: Dabee]
#957416
03/24/11 09:51 PM
03/24/11 09:51 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Right or wrong I fixed the problem. I have three new shafts so I tried each one. I also measured the shaft diameter of each one. There was about .001 to .0015 difference between the largest to smallest. The smallest diameter shaft would slip about 5/16 inch into the bushing before binding. I chucked this shaft up in my drill press and polished the shaft with 360 emery cloth for about 30 seconds followed by 600 sandpaper. The shaft went in about two inches before binding, so I gave it another 30 seconds. This time the shaft went all the way in with a nice sung fit. Thanks guys for all the good ideas.
Your a master backyard mechanic Russ! ![](/ubbthreads/images/graemlins/beer.gif) I should come down to watch you run then we can go to Karls shooting! ![](/ubbthreads/images/graemlins/grin.gif)
