Re: 650 hp in a street car.
[Re: 73cuda340]
#956921
03/25/11 11:10 AM
03/25/11 11:10 AM
BradH
Forget about the HP, but my car runs mid 10s in full street trim...
What are the specs on the motor and car?
'73 Challenger w/ 440, auto w/ 4200-stall converter, 4.10s, and the chassis is set up w/ emphasis on drag strip performance (not street handling).
[Re: Darryls-Demon]
#956922
03/25/11 03:04 PM
03/25/11 03:04 PM
Posts: 43,293 Bend,OR USA
Cab_Burge
I've had motors that throw the belts off It is usually belt and pulley alignment issues that cause it Once the belt comes off it will always come of at or above the RPM it came off at the first time, time to go buy a new belt I have been told on this site(unlawful racing) that the gatorback belts stay on better, I have several of them for different motors
[Re: DennisH ]
#956925
03/25/11 05:42 PM
03/25/11 05:42 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
My buddies '66 Beaumont street/strip car was just dynoed at 803hp.....I'm thinking it may be a handfull on the street. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: Darryls-Demon]
#956926
03/25/11 06:08 PM
03/25/11 06:08 PM
Posts: 179 Up in the North and Far Away
AutoEngineer
My .030 over 440 makes 643HP at 6300RPMs and 592lbs of torque at 4400RPMs.
Can I see the details of your combination? And do you have any ET & MPH results from track to go along with it? Thanks!
Sure here is the combo.
.030 over 440 bushed lifter bores 11.1 CR Comp solid roller cam [Email]248-254@.050[/Email], .622-.612 with 1.6 rockers all the bearings coated. MW ported SR heads Ported indy DP intake, Pro-Systems carb Lots of engine coatings- inside and out outside of the intake,tops of the pistons, sides of pistons, intake ports exhaust ports. Do all those coating help make HP? who knows, the motor does rev quick thow. Bud Yancer did the machine work and Sheldon Gecker bolted it together. No I have not had it to the track, as I said it keeps throwing the alternator belts. I need to come up with some kind of idler pulley for the belts.
Also the pistons are five out of the hole with a .039 head gasket.
What kind of modifications you have done to the body to handle all that massive power? E-body vert's chassis is not a very rigid one when stock
[Re: Mopar Grandpa]
#956929
03/25/11 06:36 PM
03/25/11 06:36 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
You all have me frightened now. my street build will be around 1,500hp/1,100 ftlbs. but power climbs higher in the rpm range ~650hp@4,500 climbs from there 6spd manual should keep rpms down on cruise.
-------------------------------- Darren Beale Keith Black Racing Engines®
[Re: 73cuda340]
#956930
03/25/11 06:45 PM
03/25/11 06:45 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
It seems some people are very concerned that these 650hp+ rides are up to snuff in terms of handling all that power. Not knocking anyone who wants to put in a cage, new rear (dana), 4 wheel discs, etc., before adding the power, but sometimes its not necessary. I know of a few people that have cars with big power engines that will probably never race them, ever. They like having the power to blaze the tires at will and the intimidation factor at the cruise ins. Don't get me wrong, I like to race my cars, but not everybody does...and big power is not so hard on parts when you're just smoking tires and doing roll-ons at 30mph.
2 kids and a dog
[Re: BradH]
#956935
03/25/11 11:09 PM
03/25/11 11:09 PM
Posts: 795 Glendale Az
Darryls-Demon
Glendale Az
Someday I would like to run the car. The subframe is tided together and it has SS springs. Iam using a A-1 8 inch conveter, low first gear set in the trans and a 3.55 rearend gear. One of the reasons the belts are flying off is the belts are very long, it is a factory AC car.
[Re: DennisH ]
#956938
03/26/11 09:19 AM
03/26/11 09:19 AM
Posts: 236 Maryland
cudaboone
Maryland
How about over 750hp in a street car?
I'll have to show my street car a trailer someday.
Hi DennisH: where did you get that hood and what is the height?
