Adding baffles to factory small block oil pan. #956813
03/23/11 09:16 AM
03/23/11 09:16 AM
NJ
JCCuda Offline OP
JCCuda  Offline OP
NJ
Looking for suggestions on adding baffles to a factory 360 center sump oil pan for oil control on acceleration and deceleration. I have some idea how I want to do it but someone may have a better idea. Pictures would be helpful.
Re: Adding baffles to factory small block oil pan. [Re: JCCuda] #956814
03/23/11 10:19 AM
03/23/11 10:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Just mount a piece of sheet steel to the front and
rear on a small angle upward... you can have it come
around the radius if you want... just clear the pick up
Re: Adding baffles to factory small block oil pan. [Re: MR_P_BODY] #956815
03/23/11 10:35 AM
03/23/11 10:35 AM
NJ
JCCuda Offline OP
JCCuda  Offline OP
NJ
Thank's Mr P Body that was what I was planning but thought maybe someone may have come up with something better.
Re: Adding baffles to factory small block oil pan. [Re: JCCuda] #956816
03/23/11 10:50 AM
03/23/11 10:50 AM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I've tried a couple of different approaches. One was as MR. P- body described. Another was to cut the bottom of another pan and cut a square hole in the original pan and then weld the other bottom to it. Naturally this requires extending the pickup. In the end neither worked as well as the low profile Milodon that I am currently using.
Re: Adding baffles to factory small block oil pan. [Re: JCCuda] #956817
03/23/11 10:52 AM
03/23/11 10:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
All depends on how much work you want to do... you
can put a couple of flat baffles in the sump so they
stop/slow the serge of oil coming up the wall... it
all helps... but the top one will direct the oil forward
so it drops back down into the pan and not be at the
back of the pan
Re: Adding baffles to factory small block oil pan. [Re: JCCuda] #956818
03/23/11 12:32 PM
03/23/11 12:32 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
here is the kevko oil pan I just picked up - have not installed it but it has what your looking for, - the tops of the sump have pans that hold the oil down - it also has trap doors for decel,
Re: Adding baffles to factory small block oil pan. [Re: DJVCuda] #956819
03/24/11 02:11 AM
03/24/11 02:11 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
This is the quick and dirty way...
Here's the new low profile Milodon Small Block Mopar #31590 road race, pro-touring pan that is actually 1/4" shorter than stock if you count the stock pan drain plug bulge. The cut in the center section creates a taller rear sump wall to prevent oil spilling backwards.
The ultimate LOW profile Small Block Mopar pan!
How's this for clearance?!?!?
Spring Fling 37 May 3 & 4, 2025 at Woodley Park, Van Nuys CA
600+ Mopars, 200+ swap, midway, Friday Malibu cruise,
Re: Adding baffles to factory small block oil pan. [Re: JCCuda] #956820
03/24/11 11:33 AM
03/24/11 11:33 AM
NJ
JCCuda Offline OP
JCCuda  Offline OP
NJ
Thank's for all the reply's. I made something up last night and a friend is gonna weld it in tonight.
