1965 B Body front disc brake conversion #956082
03/21/11 11:08 PM
03/21/11 11:08 PM
Ripley
BryanRad Offline OP
BryanRad  Offline OP
Ripley
Whats the easiest way to convert to front disc brakes on a 65 Coronet?
Thanks.
Re: 1965 B Body front disc brake conversion [Re: BryanRad] #956083
03/21/11 11:13 PM
03/21/11 11:13 PM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
I used 74 Dart spindles
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
Re: 1965 B Body front disc brake conversion [Re: BryanRad] #956084
03/21/11 11:50 PM
03/21/11 11:50 PM
Thanks.
Easiest or cheapest?
If you want easy something like a Wilwood kit uses the existing drum spindle and bolts in place with no parts hunting required. (this is what I did on my '63)
Cheap? Find an A-body and rob the spindles and caliper adapters and go buy new bearings, rotors and calipers at the parts store.
Re: 1965 B Body front disc brake conversion #956085
03/22/11 12:59 AM
03/22/11 12:59 AM
The nice thing about using the spindles from an A body is the clearance issues found with aftermarket brakes and OEM steel wheels for the early B bodies. It is also cheaper.
Re: 1965 B Body front disc brake conversion #956086
03/22/11 10:02 AM
03/22/11 10:02 AM
Andrewh Offline
Andrewh  Offline
m-bodies also work. got mine off a 80's new yorker for my 65.
Re: 1965 B Body front disc brake conversion [Re: Andrewh] #956087
03/22/11 10:33 AM
03/22/11 10:33 AM
tboomer Offline
tboomer  Offline
Bryan...I went with Wilwoods on the front of my 64...Doc Diff also sells a complete kit..
Re: 1965 B Body front disc brake conversion [Re: tboomer] #956088
03/22/11 10:44 AM
03/22/11 10:44 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I went with the SSBC basic kit.Fits your spindle and comes with 4 piston calipers.The kit had EVERYTHING in it for the install.I supplied the elbow grease
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 1965 B Body front disc brake conversion [Re: hemi-itis] #956089
03/22/11 10:51 AM
03/22/11 10:51 AM
tboomer Offline
tboomer  Offline
Al...I think that is the kit that Cass sells..Jegs may have it,too...The nice thing about those kits is that they are complete and you don't waste time trying to scrounge old rusty junkyard parts...
