MSD 6AL key on voltage connection #955206
03/21/11 12:26 PM
03/21/11 12:26 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
What is the prefered circuit for the key on signal B+ connection for the MSD box
It's a new M+H Wiring stock underhood wiring harness in a 1970 Road Runner
MSD box is going to be under the battery tray and I plan to use the radiator support for the primary ground and the B+ post on the starter relay for battery positive. And will be routed along the factory fenderwell and firewall wiring but not wrapped into it.
My initial thoughts are the J3 circut off the ignition switch coming thru the firewall bulkhead connector - using the original feed wire for the stock coil ( stock ballast will be there but non-functional)
Re: MSD 6AL key on voltage connection [Re: gtx6970] #955207
03/21/11 02:40 PM
03/21/11 02:40 PM
NY,Poughkeepsie
87MO DAK Offline
87MO DAK  Offline
NY,Poughkeepsie
MSD boxes should power and ground directly off the battery
,and no where else . The trigger wire (small red ) just needs
a 12 volt key on hot wire , to tell the box to switch on.
Re: MSD 6AL key on voltage connection [Re: 87MO DAK] #955208
03/21/11 03:27 PM
03/21/11 03:27 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
actually with a good power coming from alt and healthy wiring, the B+ source it can be wired from alt post too
the KEY source it can be the blue wire ( brown in 70 and lates ) going from ballast to coil.
Or if thinking on remove ballast resistor, then use the blue wire ( all years ) originally feeding ballast and regulator
Re: MSD 6AL key on voltage connection [Re: 87MO DAK] #955209
03/21/11 03:31 PM
03/21/11 03:31 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Any suggestions as to what circuit to get the key on signal from ?
Re: MSD 6AL key on voltage connection [Re: NachoRT74] #955210
03/21/11 03:32 PM
03/21/11 03:32 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Re: MSD 6AL key on voltage connection [Re: NachoRT74] #955211
03/21/11 03:48 PM
03/21/11 03:48 PM
NY,Poughkeepsie
87MO DAK Offline
87MO DAK  Offline
NY,Poughkeepsie
Coming directly off the alt will put lots of noise in the MSD box ,
by going directly to the batt the alt noise will get filtered.
Re: MSD 6AL key on voltage connection [Re: 87MO DAK] #955212
03/22/11 01:10 AM
03/22/11 01:10 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
The wiring directions explicitly say not to wire it to the alternator post for this reason.
You can get 12v+ switched from the positive side of the electric choke harness.
Re: MSD 6AL key on voltage connection [Re: MarkZ] #955213
03/22/11 01:58 AM
03/22/11 01:58 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
just remember the msd start switch will need to see 12 volts both went the key goes to start and went the key is on run...
some 12 volt circuits go to zero volts went the key goes to start...
take the two wires from the ballast resistor...run and start ...and connect both wires to the msd start switch...
Tony
70 AARCuda Vitamin C
Re: MSD 6AL key on voltage connection [Re: 70AARcuda] #955214
03/22/11 10:57 AM
03/22/11 10:57 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
This is what I'm going to do . Plan is to remove the 2 male spade connectors from the bulk head connector and wire the MSD box into both pinouts on the connector.
That way should the desire to remove all the hotrod stuff arise and put it back to stock. I want it to be as simple and painless as possibile
Re: MSD 6AL key on voltage connection [Re: gtx6970] #955215
03/22/11 11:02 AM
03/22/11 11:02 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I found a 12-volt keyed source under the dash and hooked my MSD to that.
Turns out I hooked it to the key buzzer - my car starts fine but doesn't shut off until I physically remove the key from the ignition slot.
Ride eternal, shiny and chrome
Re: MSD 6AL key on voltage connection [Re: gtx6970] #955216
03/22/11 11:32 AM
03/22/11 11:32 AM
NY,Poughkeepsie
87MO DAK Offline
87MO DAK  Offline
NY,Poughkeepsie
If the car is still wired the way it cam factory ,
(main feed off alt through the bulk head to the amp gauge
then back out of the bulk head to starter relay or batt?)
You will still be in line with the alt.
What MSD is saying for the box to work the way it should,
is that it needs to be hooked to the battery POS&NEG only
and no where else.The battery will filter out most of the noise in the system .
If you wire it up any other way you could have erratic idle problems,
Fouling plugs ,remember the MSD box feed's the coil all it's power.
Re: MSD 6AL key on voltage connection [Re: 87MO DAK] #955217
03/22/11 11:49 AM
03/22/11 11:49 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
But if I use the original coil pos connection to supply key start/on voltage signal it's using the ballast resistor .
Running it thru the ballast resistor and I tend to think this is abad idea , correct ?
UNLESS I run a solid wire to bypass it on the backside of the ballast.
It is a MSD dist btw, combined with an MSD blaster 2 coil.
And yes, all the cars body wiring is still stock. One of my goals here is to be able to return it back to stock with minimul effort should the desire to arise sometime in the future.
Re: MSD 6AL key on voltage connection [Re: gtx6970] #955218
03/22/11 12:00 PM
03/22/11 12:00 PM
NY,Poughkeepsie
87MO DAK Offline
87MO DAK  Offline
NY,Poughkeepsie
It should be easy then , hook the main POS & NEG from the MSD box
directly to the battery.
Hook the smaller red wire to the blue wire on the ballast but hook it
up on the same side as the feed ,so if you want to remove it ,it should be pretty simple ,and that way it is not feeding through the ballast.
Re: MSD 6AL key on voltage connection [Re: NachoRT74] #955219
03/23/11 03:09 AM
03/23/11 03:09 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
when I made this quote it was because forgot to add ( twice ), if removing ballast, NEED to splice together brown and blue wires coming from bulkhead to hook there the small red wire of MSD. If not remove the ballast wire going originally to coil is simply enough. Its just a trigger to turn it on, not a power source
Noises on system are actually produced from COIL on stock system, breaker points &/or mechanical regulators, not really the alt, but whatever! Follow the instructions going to batt or starter relay stud. Just take in mind SOME of the ammeter reading can it be some mismatched with the real status
Re: MSD 6AL key on voltage connection [Re: 87MO DAK] #955220
03/23/11 03:12 AM
03/23/11 03:12 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Partially true... On start moment, it will be triggered through ballast anyway
