Re: 8.75 clutch type power lock rear end pinion angle
[Re: tee-john]
#954314
03/20/11 11:27 AM
03/20/11 11:27 AM
RapidRobert
w flat seal, 3/4" from full forward to back seated in the cups is perfect. How much power/what app for the snubber Q (if needed). Not sure on it's clearance EDIT missed the mounting holes straight up part
[Re: DoctorDiff]
#954318
03/20/11 04:21 PM
03/20/11 04:21 PM
Posts: 606 Montana
Yancy Derringer
Montana
Pinion angle is the relationship between the transmission centerline and the pinion centerline, not to the ground and not to the driveshaft. Ideally, you want the pinion to become parallel to the transmission when the vehicle is under power and the pinion torques upward.
Make the pinion parallel to the transmission as a baseline, then pivot the pinion downward 2 degrees for a street car. This is referred to as a 2 degreee negative pinion angle.
THE ABOVE IS ONE OF MOST CONCISE, SIMPLY PUT, and IMPORTANT concepts I've ever read on here VERY well put.
[Re: tee-john]
#954319
03/20/11 04:32 PM
03/20/11 04:32 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
I purchased a rebuilt 8.75 clutch type power lock rear end to install on my 68' Barracuda. I knew that I would have to get the drive shaft shortened. I noticed that the pinion has a downward angle. If I put the mounting holes for the u-bolts straight up and down there is about 3/4" difference from center to center when I pull a measurement from the slip yoke. Is this ok and will I need a pinion snubber,and if so how close should it be from the bottom of the car? Thanks
The OP Pm'd me and said he did a rear end swap, with what dr. diff said you should see a slight downward angle at rest , especially if you have the rear up off the ground so you can get under it . As far as a pinion snubber , do you alredady have one and are asking if you need an adjustable unit ? You should have one anyway or else the yoke can contact the floor under full suspension compression.
[Re: DoctorDiff]
#954320
03/11/12 07:00 PM
03/11/12 07:00 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
Will raising the transmission up 2° give the same effect?
[Re: JonC]
#954321
03/11/12 07:20 PM
03/11/12 07:20 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
Yes, if the pinion angle is still parallel to the transmission. No matter if the transmission is up (positive) or down (negative) set the pinion angle parallel to it, either up or down, then take away 2° down (negative). So in theory the two will be parallel to each other under power.
I had a post on this very subject a couple of weeks ago. Do a search for it.
[Re: Clayton]
#954323
05/12/12 12:23 AM
05/12/12 12:23 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Doesnt U-joint angle come into play? If any of those settings gives you 0 U-joint angle then what? The reason I say is with my setup right now is gonna be tough it has 2 dgrees down at the trans and with the U-joint angle at 5 degrees down at the pinion for U-joint angle per Mopar Chassis book im still 1/2 degree negative U-joint angle at the trans. So as it sits the driveshaft comes out of the trans and angles upward.
Mopar to the bone!!!
[Re: Yancy Derringer]
#954324
05/12/12 10:03 AM
05/12/12 10:03 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Yet it leaves out one of the most important pieces of info - rear axle must be supporting the weight of rear of the car, as in not having the body of the car on stands with the axle hanging down. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: DoctorDiff]
#954327
05/12/12 03:17 PM
05/12/12 03:17 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Picture this scenario: The rear springs have a foot or two of arch -- the car is, as we used to say, "jacked up". It would be possible to shim the axle hosing (or re-weld the perches) so that the pinion was perfectly parallel to the trans's mainshaft, but U-joint angles would be through the roof!
Cruising on the highway, you'd like front and rear u-joint angles to be complimentary, and very low (but not zero). For drag racing, you need some pinion nose-down (in relation to the propshaft) so the angles remain opposite at all times. How much of an angle? A serious drag car with only leaf springs might need as much as 4 or 5 deg., which a car with better axle windup control (pinion snubber, 4-link, quadrashocks, Caltracs, etc.) would require much less. With real street tires, there's rarely a need for more than 1 to 1.5 deg.
Rick
[Re: Rick_Ehrenberg]
#954330
05/12/12 05:05 PM
05/12/12 05:05 PM
72Swinger
Nebraska
So what I need to do is compromise and set mine so that U-joint angles are at a minimum (1-3degree max) under power and with weight as it would be and call it good even though the trans will be nose down and the pinion nose up in that scenario? My ride height is pretty low and im running a Viper 6spd. I have always pictured it like the Chassis manual diagram but that is only possible with Super Stock springs. Have also read that the 2 U-joint angles need to be within 1 degree of each other for vibration harmonics. I understand the 2 degrees nose down from parallel at the pinion part but even after that im gonna be nose up in relation to the driveshaft.
[Re: DoctorDiff]
#954332
05/12/12 08:35 PM
05/12/12 08:35 PM
72Swinger
Nebraska
Ok I will Cass! Was just worried about U-joint operating angle. Shouldnt we stay between 1 and 3 degrees if possible?
