Re: This look right? (relay question)
[Re: Mr.Yuck]
#953984
03/21/11 12:16 PM
03/21/11 12:16 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I would most likely hook terminal 86 up to the ballast resistor
terminal 30 is hooked to battery power (starter relay) 85 goes to ground 87 goes to your pump
It sounds like for what ever reason your chosen switched power source isn't getting power.... Reason I'd use the ballast is you don't want power in accessory position like most stuff under the dash... & the relay draws so little power it won't effect anything.... I you want to have a over-ride switch to shut the pump down hook it up to terminal 85 so the ground is eliminated.. If you decide to add a inertia (crash) switch it also would go in the terminal 85 lead...
[Re: 1_WILD_RT]
#953985
03/21/11 12:25 PM
03/21/11 12:25 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Never thought of using the ballast. either side work? I think the Schematic had 30 going to the pump, 85 was ground, and 86/87 was to power and switch, can't remember which was which.
[Re: Mr.Yuck]
#953986
03/21/11 01:02 PM
03/21/11 01:02 PM
Posts: 2,648 GA
Boosted
GA
I run a constant voltage soleniod on my car. There is no need for a relay then. The constant voltage soleniod will only need 9v to activate it. Yhe pump will get full power then. Just a thought..
I run both of my pumps off the constant voltage soleniod.
And no it is not a ford soleniod.. They are not intended for constant power.
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
[Re: Mopar_Country]
#953988
03/21/11 03:13 PM
03/21/11 03:13 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
This helps me when using relays. http://www.classictruckshop.com/clubs/earlyburbs/projects/bosch/relay.htmI used dual 40 amp relays on my pump as recommended by Product Engineering as their pump draws some heavy current.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
