Jack identification 1970 Super Bee #953180
03/18/11 04:13 PM
03/18/11 04:13 PM
Houston Texas
PAINT IT BLACK Offline OP
Got a CHIP on my shoulder
Houston Texas
Anyone got a pic of the correct mast, base and jack for my 1970 Bee? I think mine is right, but need to make sure. I don't see any identifying part numbers on anything but the hook (which is correct). How can you tell if the other parts are right? Also, what is the correct plating of the shaft?
Is the mast, base and jack the same for a 1970 Barracuda? I know the hooks are different.
What is the best rattle can paint for these? I read somewhere that Krylon Stone Gray is pretty close. Anyone have input on this?
Re: Jack identification 1970 Super Bee [Re: PAINT IT BLACK] #953181
03/18/11 05:26 PM
03/18/11 05:26 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Nick's page might help a little...
http://www.nicksgarage.com/jacks.htm
Re: Jack identification 1970 Super Bee [Re: OzHemi] #953182
03/18/11 06:12 PM
03/18/11 06:12 PM
Houston Texas
Houston Texas
Thanks, I saw that... I'm just fishing for more info.
Re: Jack identification 1970 Super Bee [Re: PAINT IT BLACK] #953183
03/18/11 06:52 PM
03/18/11 06:52 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
No problem, just thought it might have helped to start things off with.
Re: Jack identification 1970 Super Bee [Re: PAINT IT BLACK] #953184
03/18/11 07:04 PM
03/18/11 07:04 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Yes, it is pretty close. That is what I used.
Re: Jack identification 1970 Super Bee [Re: rayztoy] #953185
03/18/11 07:37 PM
03/18/11 07:37 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Here is a 70 Super Bee set up....
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Jack identification 1970 Super Bee [Re: 70gtx440dana] #953186
03/18/11 07:38 PM
03/18/11 07:38 PM
Lansing, MI
Lansing, MI
picture #2...
Re: Jack identification 1970 Super Bee [Re: 70gtx440dana] #953187
03/18/11 07:39 PM
03/18/11 07:39 PM
Lansing, MI
Lansing, MI
and #3... Road Runner hook #103
Re: Jack identification 1970 Super Bee [Re: 70gtx440dana] #953188
03/18/11 07:40 PM
03/18/11 07:40 PM
Lansing, MI
Lansing, MI
mechanism date code...0B or Feb 1970
Re: Jack identification 1970 Super Bee [Re: PAINT IT BLACK] #953189
03/18/11 08:03 PM
03/18/11 08:03 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
What additional information would be useful to people? I want to make the page as useful as possible.
I don't know enough about them to say when you got the "T" shaped jack or the tubular one.
Re: Jack identification 1970 Super Bee [Re: NicksGarage] #953190
03/18/11 09:54 PM
03/18/11 09:54 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
70 Bee's were built at 3 different assembly plants
Lynch Road = "T" style mast
St. Louis = Tube style mast
Los Angeles = ?
Re: Jack identification 1970 Super Bee [Re: hemi70se] #953191
03/18/11 10:49 PM
03/18/11 10:49 PM
Lansing, MI
Lansing, MI
Los Angeles = ?
I agree on your Lynch Rd. & St. Louis observations for mast type......My LA built 70 Road Runner has the hollow tube style. Same as pictured above.
Re: Jack identification 1970 Super Bee [Re: 70gtx440dana] #953192
03/18/11 11:02 PM
03/18/11 11:02 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
My Lynch Road '71 Charger has the T shape. My '70 SL Road Runner has the tubular one but don't know if it's the original since I found that the hook is from a C-body.
Re: Jack identification 1970 Super Bee [Re: 70gtx440dana] #953193
03/19/11 12:38 AM
03/19/11 12:38 AM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Just for reference in this pic that is the 70 RR hook pictured as 70 Coronet or Super Bee has a 2 pins in the hook for front and rear use....
Re: Jack identification 1970 Super Bee [Re: 70gtx440dana] #953194
03/19/11 09:41 AM
03/19/11 09:41 AM
michigan
70 buzz Offline
70 buzz  Offline
michigan
I think Lynch road jacks had the solid post.
Re: Jack identification 1970 Super Bee [Re: 70gtx440dana] #953195
03/19/11 10:28 AM
03/19/11 10:28 AM
Houston Texas
Houston Texas
Thanks for those pics. My SB is a St. Louis Car and that is the type of Mast I have. My jack has an Oct. '69 date on it and that seems right for my January '70 build.
The plating looks to have a slightly yellowish tint to it. Anyone know what type of plating this is? Where could I send it for replating?
How does the Road Runner jack shown compare with a 9/'69 Hamtramck Barracuda?
Re: Jack identification 1970 Super Bee [Re: PAINT IT BLACK] #953196
03/19/11 11:01 AM
03/19/11 11:01 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Original jack for an April 1970 SBD 1970 Cuda
Dove grey mechanisims with a yellow zinc di-chromate mast .
Plating was done bt Neil at Dynamic Renovation
Re: Jack identification 1970 Super Bee [Re: gtx6970] #953197
03/19/11 11:04 AM
03/19/11 11:04 AM
It's a dry heat
It's a dry heat
closeup
Re: Jack identification 1970 Super Bee [Re: PAINT IT BLACK] #953198
03/19/11 11:36 AM
03/19/11 11:36 AM
Houston Texas
Houston Texas
Since its sort of on-topic, I'll hijack my own thread and ask about spare tires/wheels...
My car is a VERY bare bones 383 bench seat 4 speed car with pretty much no options. I am assuming it came with 14" steel wheels. Would that mean the car had a 14" spare too, and if so, what kind of date codes and tire should I look for? If the car is Fe5 Red, would the wheels and spare wheel also have been red, or would the spare have been semi gloss black? I am clueless when it comes to these trunk accessories...
Re: Jack identification 1970 Super Bee [Re: PAINT IT BLACK] #953199
03/19/11 11:57 AM
03/19/11 11:57 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
If the car had body color steel wheels the spare would be the same color wheel and tire combo. This way you could rotate the tires and include the spare. If the car had optional styled wheels the spare would be a plain black steel wheel in the same size and same tire. Wasn't meant to be included in the rotation of the tires.
1970 cars with dog dish caps had body color wheels except for Challenger T/As.
