Re: Minitubbed a-body Dana 60 length- whats yours? [Re: mshred] #952759
03/19/11 09:53 PM
03/19/11 09:53 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I use to have pics but I cut it in half horizontally the length of the "bulge" and beat it over with a BFH and then tack welded it up and then I spread epoxy across the seam and painted back over it...
Mopar Performance
Re: Minitubbed a-body Dana 60 length- whats yours? [Re: moparniac] #952760
03/19/11 09:54 PM
03/19/11 09:54 PM
Toronto
mshred Online content OP
mshred  Online Content OP
Toronto
Im losing my mind, you already told me that before and I asked again lol
one more question lol...was it before or after you had it painted? I need to hear after so that I aint scared to go at mine now lol
Re: Minitubbed a-body Dana 60 length- whats yours? [Re: mshred] #952761
03/19/11 09:58 PM
03/19/11 09:58 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
my car was already painted! there is a gap between wheelhousing and the 1/4 panel! be careful though
Mopar Performance
Re: Minitubbed a-body Dana 60 length- whats yours? [Re: moparniac] #952762
03/19/11 10:57 PM
03/19/11 10:57 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
The body saw is much smaller and has a very small stroke so it is very easy to control. Remember also where you are cutting folds back over itself, it is like you are cutting the bottom off a "C". There is probably an inch of space.
Unfortunately, my car is not here. I will be reunited Saturday, so I will take some pictures for you then.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Minitubbed a-body Dana 60 length- whats yours? [Re: clovis] #952763
03/19/11 11:11 PM
03/19/11 11:11 PM
Toronto
Toronto
pics would be great! I really appreciate this!
Re: Minitubbed a-body Dana 60 length- whats yours? [Re: mshred] #952764
03/20/11 10:32 AM
03/20/11 10:32 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
FWIW I just used a dremel and some cutoff wheels and sliced across there ...
Mopar Performance
Re: Minitubbed a-body Dana 60 length- whats yours? [Re: moparniac] #952765
03/20/11 10:43 AM
03/20/11 10:43 AM
Get-X Offline
Get-X  Offline
Don't try to use a sawz-all!! You'll make a big, expensive mess. Use a die grinder with a cut off disc, way more control.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Minitubbed a-body Dana 60 length- whats yours? [Re: Get-X] #952766
03/20/11 10:53 AM
03/20/11 10:53 AM
Toronto
Toronto
thanks for the heads up guys! Dremel with a cutoff disc it is then unless I can get my hands on something similar to that body saw
