Re: Minitubbed a-body Dana 60 length- whats yours?
[Re: moparniac]
#952760
03/19/11 09:54 PM
03/19/11 09:54 PM
Posts: 3,428 Toronto
mshred
Toronto
I use to have pics but I cut it in half horizontally the length of the "bulge" and beat it over with a BFH and then tack welded it up and then I spread epoxy across the seam and painted back over it...
Im losing my mind, you already told me that before and I asked again lol
one more question lol...was it before or after you had it painted? I need to hear after so that I aint scared to go at mine now lol
[Re: moparniac]
#952762
03/19/11 10:57 PM
03/19/11 10:57 PM
Posts: 554 Kentucky
clovis
Kentucky
The body saw is much smaller and has a very small stroke so it is very easy to control. Remember also where you are cutting folds back over itself, it is like you are cutting the bottom off a "C". There is probably an inch of space.
Unfortunately, my car is not here. I will be reunited Saturday, so I will take some pictures for you then.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: clovis]
#952763
03/19/11 11:11 PM
03/19/11 11:11 PM
mshred
Toronto
pics would be great! I really appreciate this! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: mshred]
#952764
03/20/11 10:32 AM
03/20/11 10:32 AM
Posts: 6,295 U.S.
moparniac
U.S.
FWIW I just used a dremel and some cutoff wheels and sliced across there ...
Mopar Performance
[Re: moparniac]
#952765
03/20/11 10:43 AM
03/20/11 10:43 AM
Posts: 614 Michigan
Get-X
Don't try to use a sawz-all!! You'll make a big, expensive mess. Use a die grinder with a cut off disc, way more control.
'65 Belvedere '68 GTX '57 Dodge pickup
