Re: 440 PISTONS [Re: mike s] #952630
03/19/11 03:27 AM
03/19/11 03:27 AM
Harlan, Ky
O
Orange_Duster Offline
O
Harlan, Ky
2292 is a sealed power piston for a 1970 440. Should be the same as TRW 2266.
Re: 440 PISTONS [Re: Orange_Duster] #952631
03/19/11 04:07 AM
03/19/11 04:07 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If it is I'd sell them to someone who wants to run a blower...
C/H 1.991 around 8.5 c/r
Re: 440 PISTONS [Re: Orange_Duster] #952632
03/19/11 10:55 AM
03/19/11 10:55 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Excellent example of much needed information obtained! Moparts is better than a dang library sometimes.(Even with members that are in a pre annoyed and ready to pounce state)
Keep old mopars alive.
Re: 440 PISTONS [Re: 1_WILD_RT] #952633
03/19/11 12:57 PM
03/19/11 12:57 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The 1.991 piston is not that bad as long as you pay attention to the build details. CR in the low to mid 9s is easy. Quench, well, that's another story.
Re: 440 PISTONS [Re: BSB67] #952634
03/19/11 11:36 PM
03/19/11 11:36 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
Thanks guys Thats what I was looking for. So it sounds like they are 8.5 to 9 comp. I believe the 906 heads for motor have been shaved but not sure how much yet? Maybe this well help my low compression prob. I was hoping to do 9.5 to 10.5 ball park? Any input? This is in a 70 440 hp stk crank bored 30 over using a # 3 grind mr 6pk cam & 6 pk carbs. I may change pistons .
thanks again
Re: 440 PISTONS [Re: AB&E] #952635
03/20/11 01:39 AM
03/20/11 01:39 AM
IN
ahy Offline
ahy  Offline
IN
A CR between 9 and 9.5 should be about right with iron heads. I wouldn't go higher than 9.5.
Re: 440 PISTONS [Re: 2boltmain] #952636
03/20/11 02:29 AM
03/20/11 02:29 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Moparts is better than a dang library sometimes. Even with members that are in a pre annoyed and ready to pounce state
There are GRUMPY people like that ....HERE ? ...
Re: 440 PISTONS [Re: dOoC] #952637
03/20/11 06:40 PM
03/20/11 06:40 PM
washington
AB&E Offline OP
AB&E  Offline OP
washington
Stock factory list compression for the 70 440hp was 10:5:1 I believe. But I am good with at least 9:5 with the price of fuel:
Re: 440 PISTONS [Re: AB&E] #952638
03/20/11 09:19 PM
03/20/11 09:19 PM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
70' 440hp was listed as 10:1, 440-6 pack was listed as 10.5:1. If those pistons are the same as L2266 you won't have 9.5:1 compression unless you use closed chamber heads.
Re: 440 PISTONS [Re: GTXX] #952639
03/20/11 10:34 PM
03/20/11 10:34 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Mike I have a set of these TRW 2266 flat tops.
They are .030 over very low miles.
I sold Wild Bill the crank and have no use
for them. I had them in a 440 with 906 heads and a .484 cam, it ran great.
Re: 440 PISTONS [Re: demon440] #952640
03/20/11 10:36 PM
03/20/11 10:36 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Here is a pick of the set.
Re: 440 PISTONS [Re: JohnRR] #952641
07/28/11 09:09 PM
07/28/11 09:09 PM
pana illinois
bigblock4x4 Offline
bigblock4x4  Offline
pana illinois
not to b a di**head but I just pulled a for sure,for real,440 dodge apart and the 2292p number is on the top of the pistons in that 440,i was tryin to also figure out what they were,make no mistake this is a 440 mopar that i'm workin on
Re: 440 PISTONS [Re: bigblock4x4] #952642
07/29/11 12:33 PM
07/29/11 12:33 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
the mystery has already been solved; 2292 is a Sealed Power number NOT a TRW number. As Johnrr opined, the OP was mistaken about them being TRW pistons and some knowledgable Moparts members recogized the number as a SP 440 piston.......nothing else to see here!
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 440 PISTONS [Re: AB&E] #952643
07/29/11 12:37 PM
07/29/11 12:37 PM
DPelletier Offline
DPelletier  Offline
thanks again
It's up to you, but personally I would change pistons. My 440-6 is running the same cam but I am at close to 11:1.....it runs on 94 octane pump gas, but I expect that it'll need a race fuel mix to get the timing right for the track.....we'll see. I just couldn't live with low 9's or less for compression.
