When do you need adjustable rockers on a 383? #950514
03/14/11 12:31 PM
03/14/11 12:31 PM
Orange County, CA
Mike H Offline OP
Mike H  Offline OP
Orange County, CA
Excuse my engine building ignorance upfront. I have a stock freshly rebuilt 383 (factory stock rocker arms) with a new stock cam that is only pulling 12 inches of vacuum. An engine guy told me that if the heads and/or deck have been milled too much in the past, it could be preloading the lifters too much, resulting in the loss of vacuum. The fixes I assume would be adjustable rockers or custom length pushrods, right? Forgetting any other possible causes for low vacuum, does this explanation sound plausible to you guys?
Re: When do you need adjustable rockers on a 383? [Re: Mike H] #950515
03/14/11 12:33 PM
03/14/11 12:33 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Yes you need either adjustable rockers , adjusatble pushrods or the correct length custom pushrods .
Has the block and heads been cut a lot ?
Re: When do you need adjustable rockers on a 383? [Re: JohnRR] #950516
03/14/11 12:56 PM
03/14/11 12:56 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Hydraulic lifters as a rule have a lot of forgiveness it them. with a relatively mild application and normal usage you will be fine as long as the lifter plunger is not bottoming out in the lifter. If the lifter plunger bottoms out and is tight it will hold the valve open much the same as adjusting a solid lifter with no lash. If this is happening there is a no start or the least a very poor running condition.
Re: When do you need adjustable rockers on a 383? [Re: MoparforLife] #950517
03/14/11 01:10 PM
03/14/11 01:10 PM
Orange County, CA
Mike H Offline OP
Mike H  Offline OP
Orange County, CA
JohnRR, unfortunately I don't know how much milling has been done.
Mopartforlife, that's what I always thought about hydraulics, that they "took up the slack" unless a huge amount of milling was done. The car starts/idles great, and runs smoothly at any constant rpm. The only performance problem is a major hestitaion at all rpms when accelerating, which may be due to other factors I suppose. Right now I am just trying to figure out the low vacuum.
I have heard there is a device made by Snap-On that is essentially a smoke generator. This device seals over the top of the carb and blows smoke into the engine. I assume you have to plug off all the vacuum ports, etc. Any leak produces a puff of whie smoke. My engine building friend used this device and found a grain-of-sand size hole casting defect in the body of one of the carbs on a six-pack set-up that nobody could get to run right. We're going to try it on this problem.
Re: When do you need adjustable rockers on a 383? [Re: Mike H] #950518
03/14/11 05:20 PM
03/14/11 05:20 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The hesitation could be a bog caused by the carb - too much gas or too much air. Possibly the accelerator pump or the secondaries.
I think if the issue was with the valves not closing you'd be having major starting issues, you'd be getting reversion, backfiring through the carb and severe dieseling when you shut the motor off.
As for that "smoke generator" idea, you can do the same with a propane torch. Start your engine and open the valve on the torch (DON'T LIGHT IT). Move the torch nozzle around any areas that could potentially be a leak. If there is a leak you will notice an immediate increase in RPM. Don't worry, this is a safe method, just don't forget to turn the torch off when you're done!
Re: When do you need adjustable rockers on a 383? [Re: Stanton] #950519
03/14/11 06:13 PM
03/14/11 06:13 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
12 inches isn't that low, chances are good if it's got a cam with much duration it's normal... Adding more base timing may help increase the vacuum & eliminate the bog.. there may be other issues that need looking at but I'd start with checking base timing.... Knowing cam specs would help...
Re: When do you need adjustable rockers on a 383? [Re: 1_WILD_RT] #950520
03/14/11 07:15 PM
03/14/11 07:15 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Rockers are NOT your problem. You would not be running/idling smoothly if a valve was not closing all the way.
Re: When do you need adjustable rockers on a 383? [Re: Mike H] #950521
03/14/11 07:25 PM
03/14/11 07:25 PM
Stock rebuild/cam? What year/carb? Hesitation at part or WOT. timing/lean (jets,pv,float levels)/vac leak. been a prob since rebuilt but not b 4?
Re: When do you need adjustable rockers on a 383? [Re: Mike H] #950522
03/15/11 01:25 AM
03/15/11 01:25 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
sounds like cam is retarded .
degree it, prob needs 4deg advance !
Re: When do you need adjustable rockers on a 383? [Re: Stanton] #950523
03/15/11 08:56 AM
03/15/11 08:56 AM
Virginia
RM21N0A Offline
RM21N0A  Offline
Virginia
Wow, amazing little trick.
I love this site. You never know when you are going to read something like this, that someone like myself would never even think of, no way, no how.
Re: When do you need adjustable rockers on a 383? [Re: Mike H] #950524
03/15/11 10:58 AM
03/15/11 10:58 AM
North Carolina
jt1 Offline
jt1  Offline
North Carolina
Run a compression check on it. If you're bottoming out the lifters, it will show up as low compression.
My guess is vac leak, not enough initial timing, or the pump shot needs tweaking, or maybe some combo of all.
John
