Re: Steel shim head gasket, retorque?
[Re: AutoEngineer]
#950069
03/13/11 06:40 PM
03/13/11 06:40 PM
Posts: 1,235 TN
65racer
2009 IHRA World Champion
TN
I always went thru the trouble to go back and retorque mine after the engine had been freshely fired up, and never had any of the fasteners to move after initial torque, but for the past few seasons I have been having trouble with them staying sealed up, after seasons end when the engine came apart, they would always be signs of leakage, no matter what I did, or how I prepped them, never had the problem until I started squeezing the engine more, just put a new engine in the car, and went to the thicker felpro gaskets, and just cut the block and heads some more to take up the area of the thicker gaskets, I was getting tired of taking the engine apart, and seeing black marks on the head gaskets, from leakage.
[Re: 65racer]
#950070
03/14/11 02:47 AM
03/14/11 02:47 AM
Posts: 43,251 Bend,OR USA
Cab_Burge
I used steel shims on my M.W. stocker for a lot of years when I ran it in NHRA stock, .022 thick. I've seen a lot of them have black marks bewteeen the cylinders and none of them leak bad enough to see it on a leakdown gauge Same thing on iron head 440 with the thinner .017 thick steel shim head gaskests I have blown a Fel Pro composition gasket that took the head and the block out(cut it like a cutting torch would) when it blew
[Re: quickd100]
#950072
03/14/11 09:53 AM
03/14/11 09:53 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I've never retorqued a steel shim gasket and never had one blow out on me. Dave
[Re: quickd100]
#950073
03/14/11 03:15 PM
03/14/11 03:15 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
[Re: Mike Swann]
#950077
03/15/11 12:37 AM
03/15/11 12:37 AM
Cab_Burge
I've used Copper coat, silver paint, single and 3 or 4 layers and I've put them on dry I've never blew one out I do use three different torque steps like 25, 50 and then 65 ft lbs starting on the left head first, old superstition from way back, you don't really want to know why
