Re: I've Got A Bit Of A Dilemma
[Re: pro6pakRR]
#950033
03/14/11 08:30 PM
03/14/11 08:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Mike not to sound dumb,but can't you put the rack under the frame?
No... that would put the inner tie rod to low... as the wheel goes up it would pull more toe in and it goes down it would go toe out... you want the inner rod end at the same height as the outer and the rod to be the same length as the lower control arms(which that part is fine)
[Re: B G Racing]
#950036
03/14/11 08:58 PM
03/14/11 08:58 PM
MR_P_BODY
I would not exceed the 3" angle I mentioned,but you may be able to lower the r/p move it back and use spacers between the steering arm and tierod ends,that's what I have done on Lonnie's car and others when I had to work with previous work that was done.You may also add length to the steering arms to extend them forward.
I plan on making new steering arms... which should make up about half of what I want... then I think I'll angle it some and cut the tie rod and stager it and weld it with a boot on it. If I put the rack back between the damper and the sump it would be behind the centerline of the spindle and I would have to change racks... I'll stick with this idea
[Re: MR_P_BODY]
#950037
03/14/11 09:22 PM
03/14/11 09:22 PM
Posts: 140 Fort Worth, TX
DMax One
Fort Worth, TX
What about something like the 98-99 Intrepid or Concorde steering rack? Its a center steer rack, a tab stick out about 3 inches from the rack and the tierods attach to the tab. The only problem is it is a power steering rack. Don't know if there is a manual version. On the Interpids/Concordes, its mounted on a shelf on the firewall. You'd have to flip your steering arms around to the back or ??? http://shop.advanceautoparts.com/webapp/...S_1569620878___Just a thought.
68 Barracuda FB "Exploded View" ...still :-(
2008 Ram 2500 CTD
2007 H.D. Softail Custom
92 Jeep Cherokee
[Re: SLOW67]
#950039
03/14/11 10:14 PM
03/14/11 10:14 PM
MR_P_BODY
I don't have any input but I'm glad this question came up because it was concerning me about my rack placement on an up coming K member build
Its actually pretty simple... have the inner tie rod and the inner lower arm at the same pivot point... then the outer tie rod ends level with the rack... then you would like to have the rack and steering arm at 90*.... simple.... if nothing gets in the way
[Re: MR_P_BODY]
#950040
03/16/11 12:50 PM
03/16/11 12:50 PM
MR_P_BODY
Got another idea today... my buddy and I were talking then came up with the idea of a drag link between the 2 steering arms and then tie the rack arms to it... gotta look at that idea... but I like it
[Re: MR_P_BODY]
#950041
03/16/11 02:12 PM
03/16/11 02:12 PM
Posts: 20,698 in a cattle trailer down by th...
Guitar Jones
I don't know, additional steering hardware never seems like a good idea to me.
[Re: MR_P_BODY]
#950042
03/16/11 02:21 PM
03/16/11 02:21 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I was going to suggest that but I couldnt remember the term Drag link as a way to describe it. A guy here in Ohio did that about 20 years ago and it was featured in a article in one of the mopar mags with pics. I have it around somewhere as I was going to do it too.
He pulled the tie rods out of the rack drilled it and tapped it i think. Bolted up plates and joined them across together the length of the rack and a drag link setup. That link moved the inner tierod locations up and back for his abody combo.
Dennis Laube was his name, if you want I can dig up the mag again and send you pics, " Not that you would want the Same exact fabbed piece.
[Re: Guitar Jones]
#950043
03/16/11 02:29 PM
03/16/11 02:29 PM
MR_P_BODY
Well I was looking at all the numbers and putting things in place, it doesnt look to bad at all with just using the rack... I'll have to add a wheel spacer and extend the steering arm like I wanted, then move the engine back as far as I can then still cut the tie rod and overlap them it will look good(put a boot over the tie rod) and then it wont have much angle to the tie rods
