Re: Brake Lights always on, even with fuse removed [Re: Yancy Derringer] #949459
03/13/11 08:38 PM
03/13/11 08:38 PM
TX , NJ , FL
W
WINGCARS_6970 Offline
W
TX , NJ , FL
I had cars no brakelights at all.And replaced the TS switch brake lights worked afterwards .All those related wires go back into T/S switch And incase you get only onside of the brakelights .Check the position of the T/S lever
Re: Brake Lights always on, even with fuse removed [Re: Yancy Derringer] #949460
03/14/11 12:24 AM
03/14/11 12:24 AM
NC
c5ryan Offline OP
c5ryan  Offline OP
NC
You need to ask yourself, "can this happen?" The turn signal switch normally should NOT have anything to do with tail lamps, only stop/ turn. Why would it be the brake light switch? You say the lamps are only on when the car is "cranked."
WHAT DOES THAT MEAN??
"cranked?"
Do you mean when you are cranking the engine on the starter?
Do you mean when the ignition switch is in "run?"
Do you mean only when the engine is running?
Tail Lights are on but on the dim side when the ignition is turned to on/run or when the engine is running. There is draw when the tailight fuse is installed, is not one when removed. Tailights are still on if the brake switch is unpluged. Tailights are still on if the Turn signal switch is unpluged. About 2 years ago I puched the car hard and had white/grey smoke out of hood and cut off. Wires burned off shields under hood. Was replaced and seemed to work when I got it back, I may no have noticed lights. Car was in storage for 2yrs, we had a 3rd kid and he had medical problems and just did not have time for it. Trying to get it back on road now.
Re: Brake Lights always on, even with fuse removed [Re: c5ryan] #949461
03/14/11 12:32 AM
03/14/11 12:32 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Do you have the factory radio? If not unpug the aftermarket and see what happens.
Re: Brake Lights always on, even with fuse removed [Re: NITROUSN] #949462
03/14/11 01:12 AM
03/14/11 01:12 AM
TX , NJ , FL
W
W
TX , NJ , FL
You may have another problem somewhere. I still would disconnect and evaluate the rear light harness for tampering.A reason for dim lights you describe . Could be bad ground .Or your only getting parking or running lights the low side of the 1157 bulb.The brighter side of the 1157 bulb is turn signals emergency flasher and brake lights
Re: Brake Lights always on, even with fuse removed [Re: WINGCARS_6970] #949463
03/14/11 02:56 AM
03/14/11 02:56 AM
Montana
Y
Yancy Derringer Offline
Y
Montana
This is not a "bad ground problem." I'd bet money on meltage in the harness
Re: Brake Lights always on, even with fuse removed [Re: Yancy Derringer] #949464
03/14/11 11:36 AM
03/14/11 11:36 AM
TX , NJ , FL
W
W
TX , NJ , FL
Thats probably the case .When harness tape is slit open the wire you find with the least plastic coating remaining got the hottest .Thats the one that started things off
Re: Brake Lights always on, even with fuse removed [Re: c5ryan] #949465
03/14/11 02:22 PM
03/14/11 02:22 PM
Riverside, California
ghostrider Offline
ghostrider  Offline
I unpluged the turn signal switch and the tail lights were still on. Should that happen? Advance and Autozone do not list this part on website.
Should not happen, you have a hot feed going to those rear lights from a melted wire or fuse holder. (or a bad headlight switch) Start pulling one fuse out of the fuse block at a time and see if the rear lights go out. If they do then you have isolated the circuit that is feeding the rear lights when it is not supposed to.
Must remember... my humor doesn't work on forums.....my humor doesn't work on forums. Former Mopars include 69 Super Bee, 71 Sebring, 68 Charger, 69 Charger, 78 D150, 67 300, 71 Road Runner clone, 79 T-top Doba, 67 Barracuda, 91 TC by Maserati, 68 Town & Country
Re: Brake Lights always on, even with fuse removed [Re: ghostrider] #949466
03/15/11 01:52 PM
03/15/11 01:52 PM
TX , NJ , FL
W
W
TX , NJ , FL
Any updates Found the cause yet? .Its most likely as mentioned above in the main harness power distribution.Which requires some labor to remove it.Its less labor to go through the rear harness evaluation bulbs socket conditions grounds.And finish up with main or underhood wiring corrections.As Ive seen rear wiring harness get screws into wiring under rocker sill plate damages from carpet installed .Chaffed or tapped into. Stay with it keep us informed
