Page 2 of 3 1 2 3
Re: Ray Barton HEMI Rocker System: worth it? [Re: sshemi] #948718
03/12/11 05:39 PM
03/12/11 05:39 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
unless a hardcore build with over .750 lift even factory none roller rockers can be used. I used narrow pads on a motor with a .720 lift cam for over 250 passes. never any problem. with a cost of 3500.00 it's overkill in 95% of time.
home of the
Sox and Martin Hemi Duster
Re: Ray Barton HEMI Rocker System: worth it? [Re: hemigod426] #948719
03/12/11 06:40 PM
03/12/11 06:40 PM
Petersburg, Va
Darrell Offline
Darrell  Offline
Petersburg, Va
member here is blowing out a set of t/d new hemi rockers on ebay now
Yep, he has had them for sale here in the Hemi Engine section for about 6 weeks now. I don't know how maney sets he had but I bought a set from him about a month ago. No, I didn't need them either for my 525 build, but the price was right and Mike was a great guy to deal with!!
Re: Ray Barton HEMI Rocker System: worth it? [Re: HEMIFRED] #948720
03/12/11 06:47 PM
03/12/11 06:47 PM
QLD Australia
Keith Black® Offline
QLD Australia
what about in a regularly street driven car where durability/low maintenance is also important.. ?
Darren Beale
Keith Black Racing Engines®
Re: Ray Barton HEMI Rocker System: worth it? [Re: Keith Black®] #948721
03/12/11 10:40 PM
03/12/11 10:40 PM
Can you mill off the stands off the Indy Legend heads and use the Barton Hemi T & D Rockers?
Has it been done?
Re: Ray Barton HEMI Rocker System: worth it? [Re: Keith Black®] #948722
03/12/11 10:58 PM
03/12/11 10:58 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
In that environment they are absolutly perfect to use.
They were good enough even for the first pro stock cars which revved as high as 9,000 rpm before any aftermarket ones were made.if they could stand 250 passes and 7700 rpm at the traps .
Should I chose to put a set on a motor I would consider having a used set reconditioned . Rocker Arm Specialists is the outfit that does the work.They will regrind the pads and remove any wear spots,check the bushings and replace if needed.
Dick Landy used to sell rockers that were black powered coated or plated to all the fuel guys. He would check them for proper ratio and clean them up removing any parting lines.I have seen those on many nostalgia builds. . I still have as set.
home of the
Re: Ray Barton HEMI Rocker System: worth it? [Re: HEMIFRED] #948723
03/12/11 11:29 PM
03/12/11 11:29 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Before I installed a set of Mopar Performance roller rockers I had a black set of DLI's.I beleive the MP's are made by DLI as well.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Ray Barton HEMI Rocker System: worth it? [Re: hemi-itis] #948724
03/13/11 12:31 AM
03/13/11 12:31 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
All the Mopar roller rockers I have have DLI logo on them
Re: Ray Barton HEMI Rocker System: worth it? [Re: B G Racing] #948725
03/13/11 09:23 AM
03/13/11 09:23 AM
pa
572charger Offline
572charger  Offline
pa
ray barton T-Ds on mine since 2003 7,000 + miles and 150+ 9 and a few 8 second passes never come out of adj best investment for a hemi !!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Ray Barton HEMI Rocker System: worth it? [Re: 572charger] #948726
03/13/11 01:31 PM
03/13/11 01:31 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
My point exactly . High dollar ...but the valve covers stay on longer.
Chryco
http://www.youtube.com/watch?v=YsmLj-Z44mo
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Ray Barton HEMI Rocker System: worth it? [Re: chryco] #948727
03/13/11 01:38 PM
03/13/11 01:38 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Chryco
That sounds good. I always hear the downside of a HEMI is the complicated and awkward valvetrain....I guess that anything that improves upon the original design has to be a plus.
Re: Ray Barton HEMI Rocker System: worth it? [Re: 572charger] #948728
03/13/11 03:04 PM
03/13/11 03:04 PM
QLD Australia
QLD Australia
.. no wear ..? do you reckon they're good for, say, 20,000+ miles.. how have the valves/guides worn?
durability & wear stats of the StageV, T&D, Jesel systems would be informative from anyone using them for sustained periods?
Darren Beale
Re: Ray Barton HEMI Rocker System: worth it? [Re: domingo] #948729
03/13/11 03:08 PM
03/13/11 03:08 PM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
They are worth it! I have them on my Cuda since 2003. I also drive it on the street and strip. They never go out of adjustment.
Re: Ray Barton HEMI Rocker System: worth it? [Re: DodgeCharger] #948730
03/13/11 03:16 PM
03/13/11 03:16 PM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
I've worked with them on Ralph's KB hemi. Rock solid design. Sent them back to T&D for a rebuild for $150 just because the engine was out of the car. Great customer service.
Here is the ebay link to the ones for sale. Good price. http://cgi.ebay.com/ebaymotors/mopar-per...=item2a0edf6c55
I'm Gumby dammit!
Re: Ray Barton HEMI Rocker System: worth it? [Re: Gumbydammit] #948731
03/13/11 03:27 PM
03/13/11 03:27 PM
Netherlands
72Challenger Offline
Netherlands
I've used the stock narrow ones Fred was talking about for 6 yrs now. Around 750hp started out as street/strip, but since last year race only. .670 lift / 7k rpms never had a single problem or weird valve adjustment etc. Old design, old set but works fine for me.
Re: Ray Barton HEMI Rocker System: worth it? [Re: 72Challenger] #948732
03/13/11 04:32 PM
03/13/11 04:32 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
within that lift there will never be any problems
home of the
Re: Ray Barton HEMI Rocker System: worth it? [Re: HEMIFRED] #948733
03/15/11 08:34 AM
03/15/11 08:34 AM
an8sec70cuda Offline
I have the DLI rockers on mine. Been on there for almost 5 years running mid 9s and a lot of street miles. I check the valves twice a year, but they never move really.
From what I've been told, unless you're running 8k+ rpm on a regular basis, the T&D/Barton rockers are not needed and have no benefit. Nothing wrong w/ them at all, just money you don't need to spend.
They are pretty though.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: Ray Barton HEMI Rocker System: worth it? [Re: an8sec70cuda] #948734
03/15/11 09:57 AM
03/15/11 09:57 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
The BAE rockers we just paid close to 6 grand for are the nicest rockers/systen I've ever seen. I'm not sure if they fit non BAE applications though.
Re: Ray Barton HEMI Rocker System: worth it? [Re: BobR] #948735
03/15/11 10:11 PM
03/15/11 10:11 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
'fatheads do not interchange with conventional
home of the
Re: Ray Barton HEMI Rocker System: worth it? [Re: HEMIFRED] #948736
03/16/11 04:03 AM
03/16/11 04:03 AM
Australia
Teamx Offline
Teamx  Offline
Australia
I have these Norris arms the rocker geomatry is perfect!
Re: Ray Barton HEMI Rocker System: worth it? [Re: domingo] #948737
03/16/11 08:19 PM
03/16/11 08:19 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
Chryco
Domingo I can only say one thing: Get that car out of the garage and RACE RACE RACE. This 27 go to the track and race, you have a heads up against my small block, motor to motor. 4 years ago you said you would beat every car in Peru and I'm still waiting to get beat.
Page 2 of 3 1 2 3
