voodoo gets my vote
I just went to a 60710 roller cam
258/264
207/213
.485/.485
108icl/112lsa
idles 600rpms and just hear it,got lots of mid range torque pulls right to 5800
gettin 19 mpgs in my 85 truck
318/360 heads-Q-jet
904 high stall lock up
83/4-742-3.23 sg 27" tire
stock springs are no good for a voodoo IMO
on a side note...the spring that lunati recomends is a double with a damper and reco it for all of there sb cams
the heads will have to have machine work and seals to use lunati spring
I used comp 901s and stock every thing else
they droped on with stock seals with out pulling the heads
they work fine on my roller cam,have been to 6200 with it and no valve float
the 60710 does start nosing over after 6000 rpms but is rock soild to 5800
pm me if ya want some lunati springs..I have an extra set
I am very happy with the voodoo 60710 roller cam
