Page 2 of 3 1 2 3
Re: stock block stroker big block how big do you like t [Re: FastmOp] #942384
03/04/11 11:31 PM
03/04/11 11:31 PM
nc
E
earthmover Offline OP
E
nc
nice builds here guys and fastmop have a great time at the track tomm. and keep us posted on the et's please mike
Re: stock block stroker big block how big do you like t [Re: earthmover] #942385
03/04/11 11:43 PM
03/04/11 11:43 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
There calling for rain . Plus I'm still building headers. Hope next weekend is warm and dry. But if it is I'll prolly take my SRT challenger. I really want a 7 sec timeslip out of it. Been 8.24 but I been messin with it . The valiant will be out by the end of march though.
Earthmover with the parts you already have your going to have a stout combo. Stick something together and beat on it.
Re: stock block stroker big block how big do you like t [Re: FastmOp] #942386
03/04/11 11:56 PM
03/04/11 11:56 PM
nc
E
E
nc
i hope to soon ..just been doing a little research on things thought i could have started the build sooner but work is kinda rough but i do want to race this year lol..thanks mike
oh by the way i love the car...
Re: stock block stroker big block how big do you like t [Re: FastmOp] #942387
03/05/11 12:17 AM
03/05/11 12:17 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
512....lowdeck...all 440 Source stuff assembled by BGR...un-ported SR's...850 Ray Murray ...650 Comp...Indy intake...UCC 8" with 1.76 glide....4.56 Dana....car weighs 2300# race weight. Should be good for high 8's in good air.. With ported heads and a Dominator it would really fly...
5.53 @ 125 1/8th on the launch control..more left in her!
Re: stock block stroker big block how big do you like t [Re: earthmover] #942388
03/05/11 12:28 AM
03/05/11 12:28 AM
Seaside,Ca.
TC67CUDA Offline
TC67CUDA  Offline
Seaside,Ca.
My combo:
77 440 RV block bored .060, 440 Source 4.15 crank and rods, Ross flat tops 12 to 1 compression,Indy SR Max wedge CNC ported, valve job by Scott Brown, Scott Brown solid flat tappet cam 272/280 @ .050 664/640 lift 1.6 rockers, Indy 440-2 ported intake, Pro Systems 1000 cfm 4150 carb, timing @ 38 degrees, 67 Barracuda back half ladder, 4.56 gears ,5100 stall Ultimate Converter, weight with me around 3400 lbs, shift at 6200, traps at 6500, Best so far 10.14 @ 135 Chassis Dyno @ 542 rwhp.
Re: stock block stroker big block how big do you like t [Re: @#$%&*!] #942389
03/05/11 12:29 AM
03/05/11 12:29 AM
NC
440Jim Offline
440Jim  Offline
NC
I like the 4.250" stroke crank.
With a 4.375" bore, that is 511 CID.
Works great, I love it.
Re: stock block stroker big block how big do you like t [Re: FastmOp] #942390
03/05/11 12:36 AM
03/05/11 12:36 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
My new combo only has 9 runs on it. But the tracks open tomarrow . It's a 541ci (4.375 bore X 4.5 stroke) in a 77 440 block. I guess you can say I don't agree with the hype around here . It's just a 345CnC -1 headed, ultradyne .680/.280. Bla bla bla.
These experts would hate for me to tell you it's mostly 440source stuff with stock caps lmao
it does have GRP rods though
did you need to grind alot to fit the 4.50 stroke crank with grp rods
what is the rod ratio and compression heigth on the piston
did you mill the deck
1.39 9.85 - 137 mph
Re: stock block stroker big block how big do you like them [Re: Cab_Burge] #942391
03/05/11 09:56 AM
03/05/11 09:56 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
So you think turning a stock block stroker to 6500 and under you have alot better chance of survival? Even with 12.5-1 compression? I want mine to live as long as possible.I also have a 3/8 oil pick up so I have been trying not to over rev it. How high is to high?
I shift my pump gas 518 C.I. 400 block stroker motor at or slightly above 7000 RPM, the 440 block stroker motor probally at or under 6500 RPM As far as helping make the motor live I think E85 or pure alcholol will help prevent detonation, not just the shift RPMs If your going to use race gas I would shoot for 12.0 to 1 comp. ratio or lower The last 440 block I saw that had cracked the main webs had 14.7 to 1 comp. ratio I have seen B and RB motors break the stock main caps on race gas but not on alcholol or E85, yet I treid buying some of the old Mopar brand ductile iron main cap kits last week, no luck on either the B or RB motor kits, that leaves two options on replacing the stock main caps, steel or aluminum I like steel better than aluminum
I have 440 source billet steel main caps and ARP studs!
67' charger 499 RB 10.57 at 127
Re: stock block stroker big block how big do you like t [Re: 440Jim] #942392
03/05/11 10:17 AM
03/05/11 10:17 AM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
That's what I have. I thought it was 505, but your probably right. Love your Dart.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: stock block stroker big block how big do you like them [Re: earthmover] #942393
03/05/11 10:31 AM
03/05/11 10:31 AM
gregsdart Offline
gregsdart  Offline
gregsdart please explain this center counter weight crank to me ..i have a idea of what your saying just never really heard of that..mike
also the big thing is i have -1 heads unported with 2.25 valve with a nice size cam [Email]280@50[/Email] and 731 with the rockers 1.6..
plan to hard block to bottom of water pump holes and cross bolt and girdle
The closer you have a counter weight to each pair of rods, the less stress goes through both the crank and block to offset the forces generated by the piston and rods going up and down. A crank with weights out at the ends only will smooth out vibrations, but the forces are not in line with each other. Fuelers use them, the Ford mod motors use them, to name two.
Most believe that the upper limit for Hp in a well done low deck is in the 800 hp area. Anything you can do to even out things and reduce reciprocating weight is going to help a lot.
The cam sounds like it will make power up to about 6800 rpm. I shifted my deal at 6800 with a 283/290 @ .050 cam with .717 lift.
Re: stock block stroker big block how big do you like them [Re: gregsdart] #942394
03/05/11 11:35 AM
03/05/11 11:35 AM
nc
E
E
nc
Re: stock block stroker big block how big do you like them [Re: earthmover] #942395
03/05/11 12:18 PM
03/05/11 12:18 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
There was a guy on a few weeks ago that built a bracket stroker that had a really conservative cam in it, but it was going in a light car and it was going to be both quick and consistent, it was an interesting read and to me what he was doing made perfct sense and it goes back to my early day of bracket racing (when i had time and resources to go every week-end). The guys that always went to the money rounds week after week always seemed to have very basic combos (like 468 chevies and under carbed 340's) that were just dead-nuts reliable and eerily consistent; to a man each one of them said to go rounds you want to build the motor to about 90% of it's potential, keep the revs down and focus on the chassis tuning and cutting lights, don't chase that last .01 of et, I always thought it was really good advice. Keep it in the sweet spot where it's consistent, reliable and easy on parts.
I always applied that in a practical sense that once you get past that 90-ish percent level, the incremental gains are smaller and also A LOT MORE EXPENSIVE, plus you supersize it by pushing your whole investment harder, for some that's the dream and ambition and that's great and more power to them, but sometimes it's just as easy to cut the car weight down and go just as fast while still keeping the motor (usually the biggest $$$ investment) on the safe side of the redline.
The original question was "how do you like to build them?", which means it's anyone who chimes in personal opinion, so to my mind there's really no 'wrong answers'...I'm getting a little (well really A LOT) tired of all the that nearly every 2+ page thread degenerates to, about to the point where I might need to take a break, maybe just 'lurk' a while to see which direction this website / forum wants to go
WIZE
In Car:
Re: stock block stroker big block how big do you like them [Re: Streetwize] #942396
03/05/11 12:34 PM
03/05/11 12:34 PM
nc
E
E
nc
its alot of that streetwize just have to look over it or as you said take a little break...you get guys that will open post with nothing good to say or with the intent to piss on others thoughts or what others have done...anyway i think you all the others for the great amount of help and hope that you and others will keep the good tech/info and help going for guys like myself that has not been there dont that yet....so take the weekend off and enjoy ...come back with a open mind i know how it goes i have done it myself lol mike
Re: stock block stroker big block how big do you like them [Re: earthmover] #942397
03/05/11 01:16 PM
03/05/11 01:16 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Detonation=death. It always seems that turbo mopars can run 800+ hp on a stock block with zero issues but N/A they get pounded to death. I'm no expert and I haven't stayed at a Holiday Inn Express in ages, but I think this is because a turbo motor only runs 20 odd deg of timing for one and they don't as a rule spin the wee out of it for two. My money is on the timing.
I have a friend that does some pretty cool R+D for the Big 3 and he had pressure transducers installed in the combustion chamber of an EFI'd Brand X engine. You would be astounded at how much detonation goes on that you can't "hear" but with this technology you can "see" it as pressure spikes. With the engine on the dyno, you could add or subtract timing on the fly and it would start to show up several degrees retarded from "stock". It was considered acceptable in a stock engine because it didn't adversely affect reliability but now with increased emissions restrictions, any uncontrolled combustion is a problem.
From a performance standpoint, when you add more displacement along with compression that pressure spike increases exponentially. You still don't hear it and it isn't enough to show up on your plugs either but it is hammering your bottom end to death just the same.
Kevin
Re: stock block stroker big block how big do you like them [Re: Twostick] #942398
03/06/11 05:12 AM
03/06/11 05:12 AM
nc
E
E
nc
Re: stock block stroker big block how big do you like them [Re: Streetwize] #942399
03/06/11 11:48 AM
03/06/11 11:48 AM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
I sure would hate for that to happen Wize. I truly look forward to your posts and have based my build on your advice. For those of us that are less experienced, namely me, I hope you stick around and continue to provide your input.
Re: stock block stroker big block how big do you like them [Re: ChrgrCuda] #942400
03/06/11 12:24 PM
03/06/11 12:24 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
My first big block build is still residing between my fender wells. Welded 4.15 crank, LY rods, stock caps, stock 69 block no fill, Ross flat tops, ARP main studs, MP rod bolts. Pieced the engine together in the early 90's. Have freshened it and changed heads, but still has the same lower end. Cam was the fan favorite mechanical Ultradyne NF-69 .640 lift. It's always been best with a shift light setting of 5600-5800 rpm. Have shifted higher but didn't change a thing. Ran 4.56 gears, but after we installed a dominator (discovered our top end poor time issues...choking) our trap rpms went up to near 7k, so we dropped down to 4.10's and picked up + brought the rpm down to a more manageable 6200. If/when it fails I'll build another. Best et to date is a 10.04 at 138 in my Mirada.
Re: stock block stroker big block how big do you like them [Re: ChrgrCuda] #942401
03/06/11 12:24 PM
03/06/11 12:24 PM
gregsdart Offline
gregsdart  Offline
I like Streetwise comments on 90 percent. If you are going to bracket race, go after it with a vengeance. Build to run hundreds of runs between rebuilds. If you like to chase ET, well, its' gonna cost ya! The cam and heads you have are a good bracket motor start, provided the lobe profiles on the cam are moderate. Be sure to pick your valve train parts very carefully for the intended use.
Re: stock block stroker big block how big do you like them [Re: gregsdart] #942402
03/06/11 02:04 PM
03/06/11 02:04 PM
nc
E
E
nc
this is a good info from you guys and i do thank you all. ..as far as the valve train i have most of the parts for the build ..
parts list
-1 heads with 2.25 valve (should go 350)
t&d 1.6 rockers
440-2 single plan intake with 2" spacer for 4500 carb
howards 7.125 alum. rods (mopar bearing)
lunati cam 280 @ 50 731 lift with 1.6 rockers
440 block have not done anything to it as of yet being collecting info...
also have pushrods that came with the heads off of a 440 build
the car this motor will be in is my 70 duster it will have ladder bars,coil overs, and the frontend will be changed over to coild overs and rack,will be useing fiber glass on the hood,bumpers,and maybe the doors,the car is mini tubbed now and have had a 29/10.5w on it before on a 10" rim so i would like tostay around that size tire out back,headers we are going to try and build if we dont find a good set for a good price lol..car will be foot no trans brake
so with this combo of parts you guys tell me what you would build..
Re: stock block stroker big block how big do you like them [Re: earthmover] #942403
03/06/11 06:18 PM
03/06/11 06:18 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The 451 low deck was deadly consistent and very durable. I think if I had replaced valve springs on it after ten years it may still be running?
It was a pump gas 11:1 compression build with a mild solid roller 251/251 @50, 0.620"/6.20" cam and brodix B1 B/S heads. I would estimate the engine may have made close to 580 HP at the crank? Chassis Dyno was only 452 HP at the rear tires?
Bottom end was just ARP studs and 1/2" pickup with larger oil pan.
4,150# '71 Charger with near stock suspension (bad 60' times), 3,500 stall 10" converter (launched at 1200-1500 RPM, any more the sires would smoke off the line), 3.91 gear, and 10x27" MT street ET radials. At Bandimere, 12.50@110 (consistent) usually only varied 0.02 either way? Consistency may have been because I had no air scoop, so the air was more consistent temp coming through the radiator? Took the car to MATS, and ran 11.8's @ 115 off the trailer with no tuning changes.
I hope the new 500" 4.15" stroke, low deck works as well, but with 100+ more HP. 557 rear wheel HP on the chassis dyno. I went with the BCR caps and girdle on this engine. max wedge victor heads, and flat tops give me 12.4:1 compression.
This engine uses an agressive solid roller cam (Comp HXL Lobes), 264/264 @ 0.050", 0.714"/0.714" lift. Indy 400 single plane for my old 4150 style Holley 1,000 cfm carb. I'm sure there is more in the engine if I used a larger cam, and intake/carb, but it looks like my shift points will be close to 7,000 RPM as it stands.
Right now this is more engine than my car is set-up for. I'm looking at getting a roll bar, dana60 spooled axle, and a new driveshaft.
Page 2 of 3 1 2 3
