Page 13 of 13 1 2 11 12 13
Re: New 5.7 hemi eagle head [Re: MattW] #934537
03/12/15 09:29 PM
03/12/15 09:29 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
MattW, have you ever flowed a stock 6.1 head? Not Webers inflated numbers
That is the only head I'm missing. And my quote was from the numbers on that site
I know BES did not favor the eagle head too much. they said it needed more work than the 6.1 to achieve the numbers for the first engine master challenge that the G3 won.
Matt
Ill be flowing a set in about a hour and our numbers have been identical
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: New 5.7 hemi eagle head [Re: MattW] #934538
03/12/15 09:31 PM
03/12/15 09:31 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
.1 74
.2. 141
.3. 214
.4. 261
.5. 292
.6. 301
I like the eagle and apache head better.
So far I havnt been able to match my eagle head porting it but ive read the 6.1 is better but Im not sure. Im being conservitive though because their not mine
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934539
03/12/15 10:33 PM
03/12/15 10:33 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Something I find completely perplexing is none of the gen 3 flow numbers that come from this site are even close to the numbers from the LX forums. All of ours are also always very similar, sometimes identical yet over there they are also very similar to each other from various vendors.
This is not the case when I go to the LS tech forums. I port alot of LS heads and every time my flow numbers are right in line with theirs. Even aftermarket. A TEA cnc square port flows 370, i get 370. AFR 225cc goes 325, on my bench the number are almost exact. Its always consistant
I called one of the hemi vendors that nobody likes, Inertia. He would not talk flow numbers and I know why, because all of the other hemi vendors are full of crap and I think he argues with them over there. Im not on there enough to know what the deal is though
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934540
03/12/15 11:00 PM
03/12/15 11:00 PM
old westchester
mcat4321 Offline
mcat4321  Offline
old westchester
as some of you guy's know, i am fairly good friends with Tony Bischoff... yes, that Tony Bischoff, his favorite saying he probably uses every day..."you cant race a flow bench"
Re: New 5.7 hemi eagle head [Re: mcat4321] #934541
03/12/15 11:14 PM
03/12/15 11:14 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Your everyones friend
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934542
03/12/15 11:22 PM
03/12/15 11:22 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
.2. 141
.3. 214
.4. 261
.5. 292
.6. 301
Do you have the hemi in that car? reason i'm going to use the same car got any photos?
Re: New 5.7 hemi eagle head [Re: cudaman1969] #934543
03/12/15 11:33 PM
03/12/15 11:33 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
.2. 141
.3. 214
.4. 261
.5. 292
.6. 301
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934544
03/12/15 11:48 PM
03/12/15 11:48 PM
slammedR/T Offline
slammedR/T  Offline
Once i blow up this magnum motor or get my times I want on the race tune, I will be starting my Gen III hemi collecting. I want to go 6.4 block and apache heads with a BIG! turbo or maybe twins
racemagnum
Re: New 5.7 hemi eagle head [Re: slammedR/T] #934545
03/13/15 12:11 AM
03/13/15 12:11 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Im not sure you can put enough valve spring on Apache heads to control the valves under alot of boost. The guide is held in place by aluminum boss on top of the port where on a 6.1 head the aluminum boss is in the port. The thitek head might be the best route for a serious effort
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934546
03/13/15 03:01 AM
03/13/15 03:01 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
My cnc'd 6.1's don't have a lot of meat removed except guide transition and roof then some more on the short turn. Pretty conservative program it looks like.
Mopar to the bone!!!
Re: New 5.7 hemi eagle head [Re: 72Swinger] #934547
03/13/15 07:43 AM
03/13/15 07:43 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Whos cnc heads do you have?
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934548
03/13/15 09:38 AM
03/13/15 09:38 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
.2. 141
.3. 214
.4. 261
.5. 292
.6. 301
Thx for sharing info
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934549
03/13/15 02:18 PM
03/13/15 02:18 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
PWR.
Re: New 5.7 hemi eagle head [Re: cudaman1969] #934550
03/14/15 02:22 PM
03/14/15 02:22 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Ok i have read this entire article. questions
1. bore-stroke of the 5.7
2. bore-stroke of the 6.1
3. bore-stroke of the 6.4
if going to bore-stroke the engine, would the 5.7 be the least expensive(it will be in the car)?
can the early heads on the 5.7 be ported to the size of the eagles?
I'm confused on the cams working with the older vs new head? machined differently? My project was to find an older Challenger then install the 6.1 engine,($5200.00) now it looks like the 5.7 would could be made up just as well, later upgrade to the hellcat supercharger. This is all new to me so steer me right please.
1 3.92 x3.58
2 4.055x 3.58
3 4.090x 3.72
4 bore and stroke will be cheapest depending on which block is cheapest.
yes
don't know about finding a new 6,1. good luck and jump on it if you find one.
Matt
"don't know about finding a new 6,1. good luck and jump on it if you find one"
can get a used one with 59,000 miles for $5200 out of a Charger with accessory's and boxes or one for $4,000 with 100,000 miles. maybe sell the 5.7
Nigel has 1 left. Less money than used.
http://nationalmoparts.com/lx-lc-parts?p...ategory_id=1839
Kevin
Re: New 5.7 hemi eagle head [Re: Twostick] #934551
03/14/15 06:08 PM
03/14/15 06:08 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
sold that one a long time ago.
