Page 1 of 13 1 2 3 12 13
New 5.7 hemi eagle head #934297
02/21/11 09:20 PM
02/21/11 09:20 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Well I just picked up a set of 09 heads and I have to say HOLY S*#T.
I will probably get flamed for this statement and by all means do want you want, but Why would anyone want to build a R3. Here you have a cylinder head that will flow 300cfm out of the box without any work and a factory valve job.
I will go out on a limb and say that the hemi is the best smallblock head ever produced. Be it a production head, W series or and INDY head !
We will see what this head is capable of.
By then way this head is complete with spark plugs for under 300 US.
Let the bashing commence. Matt
Re: New 5.7 hemi eagle head [Re: MattW] #934298
02/21/11 09:53 PM
02/21/11 09:53 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
pictures or we dont believe you
Re: New 5.7 hemi eagle head [Re: MattW] #934299
02/21/11 09:56 PM
02/21/11 09:56 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
$300 a piece sounds like a steal!
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934300
02/21/11 09:57 PM
02/21/11 09:57 PM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
got my own set for 530 out the door. still waiting to get them (out of state)
Now an affordable rotating assembly would be nice.
a 392 forged stroker for 1300$ would be nice.
justin
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: New 5.7 hemi eagle head [Re: MattW] #934301
02/21/11 10:02 PM
02/21/11 10:02 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
bring it on EAGLE HEAD
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934302
02/21/11 10:08 PM
02/21/11 10:08 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
What pictures would you like?
Re: New 5.7 hemi eagle head [Re: wldtm] #934303
02/21/11 10:13 PM
02/21/11 10:13 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
justin
Well for the price of an R3 you could get a 6.1 rotating assembly. Oh by the way that comes with a block and assembled Matt
Re: New 5.7 hemi eagle head [Re: MattW] #934304
02/21/11 10:23 PM
02/21/11 10:23 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
we gotta see how long those super duper heads take before all that power blows up the block u have to use
Re: New 5.7 hemi eagle head [Re: MattW] #934305
02/21/11 10:23 PM
02/21/11 10:23 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
intake port, combustion chamber, ex port
Re: New 5.7 hemi eagle head [Re: fishy340] #934306
02/21/11 10:28 PM
02/21/11 10:28 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Unfortunately you R right. We need a block similar to the LSX for around 2000.00
But they are pushing the factory block to 700 hp
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934307
02/21/11 10:32 PM
02/21/11 10:32 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
I will have it for you tomorrow.
I would like to know how much has to be milled from the head to fit the Jesel rockers?
Would it weaken the head
Re: New 5.7 hemi eagle head [Re: MattW] #934308
02/21/11 10:51 PM
02/21/11 10:51 PM
Renton Washington
Triple Threat Offline
Renton Washington
$3,000 for the Jesel setup shall weaken your wallet.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: New 5.7 hemi eagle head [Re: Triple Threat] #934309
02/21/11 11:00 PM
02/21/11 11:00 PM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
Harlan Sharpe has what you need. What is max lift you can get on that Head?
Re: New 5.7 hemi eagle head [Re: Cuda367] #934310
02/21/11 11:18 PM
02/21/11 11:18 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
no link????
Re: New 5.7 hemi eagle head [Re: MattW] #934311
02/22/11 02:16 AM
02/22/11 02:16 AM
San Angelo, Texas
W8n2DustU Offline
W8n2DustU  Offline
San Angelo, Texas
justin
which block can handle the most power? Until they are truly tested I would stick with the Jr. How much are the new Mopar aluminum gen III block?
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: New 5.7 hemi eagle head [Re: W8n2DustU] #934312
02/22/11 10:29 AM
02/22/11 10:29 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Some of the forced induction are making up around 1200 hp.I think the 6.1 is the stronger one but BES did use a 5.7 for their Engine Master Challenge build up. 700 hp out of a 417cid on pump gas with a hydraulic.
The aluminum blocks are 4000.00 to 4500.00. Matt
Re: New 5.7 hemi eagle head [Re: W8n2DustU] #934313
02/22/11 10:37 AM
02/22/11 10:37 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Apples to oranges IMHO, compare the new Hemi block to a production 340 or 360. Now the new aluminum Hemi block to a R-3 would be a fair question.
The only thing holding me back on a new hemi is valve train parts and cams. From what I've read a 650-700 hp pump gas street/strip is not out of the question.
What is the p/n for the complete heads?
Re: New 5.7 hemi eagle head [Re: justinp61] #934314
02/22/11 10:55 AM
02/22/11 10:55 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
53021608DE 53021609DE left and right head.
Make sure you look at the laser scan on the head. The number is there also. They have been known to mix up the heads. Matt
I am trying to post picture but having a hard time.
Re: New 5.7 hemi eagle head [Re: MattW] #934315
02/22/11 11:21 AM
02/22/11 11:21 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
can someone please tell me if you can swap the heads to turn the manifolds around?
Re: New 5.7 hemi eagle head [Re: sixpackgut] #934316
02/22/11 11:45 AM
02/22/11 11:45 AM
MI
Blown69 Offline
mopar addict
Blown69  Offline
mopar addict
MI
If you want to point the manifolds forward go ahead. You just will be eliminating the EGR port
